I have just bought a Beovision 8-40 and my mom will pick it up for me. It is with floor stand - it that easy to remove? Is it just like the wall mount on a Bv 8-32 or 8-26?
It's easy, just four screws. But: Removing is best done with two persons. One holding the TV set and the second will remove the 2 screws on the left and the other two on the right. Then the TV can be lift off the floor stand. To operate the screws you need a TORX T15.
And try to get the original delivered table stands too :)
Ralph-Marcus
Thank you - just the answer I needed. Good to know precisely the screws also :-) There will be two persons to removing it.
