Yes, this is great solution:
http://archivedforum2.beoworld.org/forums/t/23652.aspx
Wat is er defect? Loopt hij aan of komt er helemaal geen geluid meer uit?
Er zit verschil in de S45. De eerste heeft foamranden die vergaan. De tweede heeft rubberen randen en kans op verschoven magneten.
You cannot see the problem from the front.Has the cone seized?
Oh yes.It's one of the good old ones with rubber.That's the one where the magnet dislocates and clamps the voicecoil.
Will the cone move easily if you press it in and out carefully?If not, the magnet has dislocated. That happens when moving these speakers but canbe repaired if you are a fairly good DIY'er. See the link I gave you above.
In the video you are pressing on the domed dustcap.Don't do that.You need to move the cone - that's the cardboard "funnel-like" part., but it would've moved by your pressingon the dustcap if it was fine - And it isn't. Back to the link I provided in my first reply.
Post them to me.....I'll fix them and return them for the cost of postage
Het probleem van de S45 is waarschijnlijk inmiddels opgelost? Als de conusrand verteerd is, dan is het een kwestie van refoamen.
