Beovox S45
This post has 18 Replies | 1 Follower
kunsf00
Posts 81
Silver Member
kunsf00 Posted: Tue, Jan 16 2018 6:17 PM
De woofer van één van mijn Beovox S45 boxen is kapot. Heeft iemand voor mij een oplossing?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Jan 16 2018 8:24 PM
Yes, this is great solution:
http://archivedforum2.beoworld.org/forums/t/23652.aspx
Blackrix
Posts 947
Blackrix replied on Tue, Jan 16 2018 9:25 PM
Wat is er defect? Loopt hij aan of komt er helemaal geen geluid meer uit?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Jan 16 2018 9:51 PM
Er zit verschil in de S45. De eerste heeft foamranden die vergaan. De tweede heeft rubberen randen en kans op verschoven magneten.
kunsf00
Posts 81
Silver Member
kunsf00 replied on Thu, Jan 18 2018 8:22 AM
Dillen
Posts 13,191
Dillen replied on Thu, Jan 18 2018 10:00 AM
You cannot see the problem from the front.
Has the cone seized?
kunsf00
Posts 81
Silver Member
kunsf00 replied on Thu, Jan 18 2018 10:06 AM
I know Martin. But Beobuddy ask me of the speaker has foam or rubber. Thats wij de picture of the front. I send also pictures from the inside.
Greetings,
Fred
kunsf00
Posts 81
Silver Member
kunsf00 replied on Thu, Jan 18 2018 10:18 AM
kunsf00
Posts 81
Silver Member
kunsf00 replied on Thu, Jan 18 2018 10:19 AM
Dillen
Posts 13,191
Dillen replied on Thu, Jan 18 2018 2:27 PM
Oh yes.
It's one of the good old ones with rubber.
That's the one where the magnet dislocates and clamps the voicecoil.
kunsf00
Posts 81
Silver Member
kunsf00 replied on Thu, Jan 18 2018 3:55 PM
Hoi Martin, can you see the problem ON the pictures. The big speaker dosn’t work from both speakers.
Fred
Dillen
Posts 13,191
Dillen replied on Thu, Jan 18 2018 4:53 PM
Will the cone move easily if you press it in and out carefully?
If not, the magnet has dislocated. That happens when moving these speakers but can
be repaired if you are a fairly good DIY'er.  See the link I gave you above.
kunsf00
Posts 81
Silver Member
kunsf00 replied on Fri, Jan 19 2018 9:48 AM
Hi Martin,
The cone move’s easily if I press it in and out carefully?
So I think the magnet has not dislocated. What can I check next. Do you have any Idee?
Greetings Fred
kunsf00
Posts 81
Silver Member
kunsf00 replied on Fri, Jan 19 2018 9:54 AM
Hi Martin, I also send you a movie ON your privat e-mail adres.
Fred
Dillen
Posts 13,191
Dillen replied on Fri, Jan 19 2018 2:52 PM
In the video you are pressing on the domed dustcap.
Don't do that.
You need to move the cone - that's the cardboard "funnel-like" part., but it would've moved by your pressing
on the dustcap if it was fine - And it isn't.
Back to the link I provided in my first reply.
kunsf00
Posts 81
Silver Member
kunsf00 replied on Fri, Jan 19 2018 3:06 PM
Thanks Martin
Craig
Yarm, United Kingdom
Posts 2,040
Silver Member
Craig replied on Fri, Jan 19 2018 7:30 PM
Post them to me.....I'll fix them and return them for the cost of postage
kunsf00
Posts 81
Silver Member
kunsf00 replied on Fri, Jan 19 2018 7:38 PM
Dear Graig, both the speakers have de same problem that de woofers not work. I don’t know where i have to sent them to. Please sent me a privat e-mail to: fredkunst1956@hotmail.com
I will also check what the shipping costs are.
Many Thanks, Fred Kunst, Maardijk 69, 7606 KS Almelo (Netherlands)
Kees
Posts 6
Kees replied on Wed, Mar 10 2021 9:09 AM
Het probleem van de S45 is waarschijnlijk inmiddels opgelost? Als de conusrand verteerd is, dan is het een kwestie van refoamen.
Page 1 of 1 (19 items) | RSS
