Connecting Macbook air to Beovision 7-40
oanceab
Posts 3
oanceab Posted: Thu, Jan 18 2018 8:25 PM
hi everybody,
I just bought a beovision 7-40 from one guy and I am quite happy with it but I cannot connect my Macbook air to the TV.;
specifications of the tv are below in case they help identifying the model;
Type No : 9354
Item No : 1817000
Serial No : 19097031
I am using a HDMI cable from laptop to tv; the tv has a DVI- HDMI connection in the back and that is the only way I can connect them; once both of them are on and connected through the HDMI cable, the laptop has one option in the top part saying " mirroring beovision 7" which comes active but there is no image on the tv ;
Can anyone help me please? I have tried going in the connections menu but don't know what is wrong as any option I choose on the "source" -still nothing is changed;
Could the HDMI connection in the back of the tv be damaged? but in this case the  laptop wouldn't see that option with the tv ( mirroring beovision 7 )
thank you;
any advice is very much appreciated
elephant
AU
Posts 8,219
elephant replied on Sat, Jan 20 2018 12:33 AM
So good news is the Mac recognises the BV even to knowing the manufacturer and model
My assumption is that you have a settings issue in the BV
You need to assign the DVI port to a source and select the source via your Beo4
I have my Mac connected to the first HDMI port and Iassigned to the PC source
Turn on you BV
Press Menu on the Beo4
You will the be able to navigate the menus to find which AV ports and Sources you are using and then pick an empty one and set that up as say PC and DVI
Good luck !
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Sat, Jan 20 2018 7:01 AM
Some menu screen shots for you
Yours should be similar
Press MENU
Select OPTIONS
Select CONNECTIONS
My Mac is on AV3 as PC connected to HDMI A
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
A BV7-40 with the type number 9354 must be a MK1 version.
Adding ‘PC’ to the List on Beo4 is required - in order to open the used input port called ‘PC’.
If sound from the Mac is requested, use seperate audio cables.
The connection panel will probably look like this:
The ‘DVI- HDMI connection in the back‘, that you mention, probably is an adapter already plugged into the DVI-port (?)
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
