It seems to me to be ok....
....as long as you have given the sub the role of a R/L sub in the settings on the tv.
I also assume, that your other speakers are set up correctly/given the right Speaker Roles etc.
The Avant basicly knows how to bas management on its own - as long as you don’t ‘mess up’ with the Advanced Settings.
However, you should read or re-read this article:
http://www.tonmeister.ca/wordpress/2014/01/10/bo-tech-subwoofer-tweaking-for-beginners/
for more details.
Go right to the chapter called How to do it (Finally!) for inspiration on further tweaking
My answer for you will - I assume - be here shortly.
It went - for reasons unknown - into moderation ;-)
this is correct and bass management should be set to on
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
You can now just play with the phase switch to hear what position is the best (there is no « good » setting for this switch, it really depends of your setup and speaker placement. Sometimes the sub can « cancel » the lower end of your main speakers or add too much on the crossover zone. This switch is there to prevent this.
diisign.com
rxcohen:this is correct and bass management should be set to on
BeoNut since '75
Millemissen:My answer for you will - I assume - be here shortly. It went - for reasons unknown - into moderation ;-) MM There is a tv - and there is a BV.
OK - this is the shortest version:
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:B&O of Manchester have a good video regarding setup of Beolab 19: https://youtu.be/FNCMQ7lsJsw
Aussie Michael:Thanks I have given the role of the sub as SUBWOOFER - i dont see any R/L in the TV just on the 19 itself.
Sorry, that was what I meant...
....in opposition to R or L, which is used if you have 2 subs.
Excellent!
mbee:You can now just play with the phase switch to hear what position is the best (there is no « good » setting for this switch, it really depends of your setup and speaker placement. Sometimes the sub can « cancel » the lower end of your main speakers or add too much on the crossover zone. This switch is there to prevent this. diisign.com
