I purchased this new in 1984, and I vividly recall it cost $385.00 back then. Unfortunately, it was set up under a pipe that developed a sudden leak; it got wet, but not soaked. I caught the leak right after it started. It frankly doesn't even look like it got wet other than on the dust cover, but I can't be 100% sure.
Unfortunately, the turntable is now stone dead.
Any thoughts here? This was my prized possession for years....
Normal diagnose procedure would be to check the power supply.Check AC to the transformer,AC to the rectifier,DC on the filter capacitor.
