Beogram 2000 got wet and now won't work
This post has 1 Reply | 2 Followers
SnuffyJon
Posts 1
SnuffyJon Posted: Sun, Feb 4 2018 2:53 AM
I purchased this new in 1984, and I vividly recall it cost $385.00 back then.  Unfortunately, it was set up under a pipe that developed a sudden leak; it got wet, but not soaked.  I caught the leak right after it started.  It frankly doesn't even look like it got wet other than on the dust cover, but I can't be 100% sure.
Unfortunately, the turntable is now stone dead.
Any thoughts here?  This was my prized possession for years....
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Feb 4 2018 7:38 AM
Normal diagnose procedure would be to check the power supply.
Check AC to the transformer,
AC to the rectifier,
DC on the filter capacitor.
Page 1 of 1 (2 items) | RSS
