Hi!
I bought a Beolink Coverter 1610 sw 1.1.
Maybe it is not good to connect a Beomaster 5500 with a Avant 32 DVD.
BUT, I found inside a switch: "Central 1610" and "Local 1611"; someone know the function??
Thank you very much!!!
If your BeoMaster 5500 has a datalink output (7 pin DIN), you simply connect it to the converter via a 7pin DIN cable, connect the Avant to the same converter via a Masterlink cable, set the correct options depending on your setup (with a remote control, setup your audio master to option 0,1 or 2, and same for your TV), plug the converter to power, and voilà!
Thank you for your answer Christophe! Any idea about internal switch??
