Converter 1610
sassella
Posts 2
sassella Posted: Tue, Oct 9 2012 1:28 PM
Hi!
I bought a Beolink Coverter 1610 sw 1.1.
Maybe it is not good to connect a Beomaster 5500 with a Avant 32 DVD.
BUT, I found inside a switch: "Central 1610" and "Local 1611"; someone know the function??
Thank you very much!!!
Christophe
Cape Town
Posts 94
If your BeoMaster 5500 has a datalink output (7 pin DIN), you simply connect it to the converter via a 7pin DIN cable, connect the Avant to the same converter via a Masterlink cable, set the correct options depending on your setup (with a remote control, setup your audio master to option 0,1 or 2, and same for your TV), plug the converter to power, and voilà!Smile
sassella
Posts 2
sassella replied on Wed, Oct 10 2012 10:28 AM
Thank you for your answer Christophe! Any idea about internal switch??
Page 1 of 1 (3 items) | RSS
