Hello all,
Does anyone know if the Picture Mute function completely turns off a Beovision screen?
or does it just make the screen black? (with backlit working in the background)
Thank you in advance!
BeoNut since '75
Thanks Elephant!
Then Picture Mute function doesn't do what I hope it would (save of screen life and heat production during summer)
Thx elephant, you saved me from purchasing a Beo4 mk3 to replace my older Beo4 :)
BEOrganic:Thx elephant, you saved me from purchasing a Beo4 mk3 to replace my older Beo4 :)
Nop, my Beo4 MK2 does not provide P.Mute in Add to List. Oh well, no biggy since it doesn't turn screen completely off anyway..
Back in the days with Beolink 1000 & MX7000 it was "picture" and "mute" - something like this must also be at beo4 mk2 and mk1
elephant:Only turns screen to gray !
I can confirm on my BV8-40 : at first it turns the screen black (backlight stays on, and infos like volume appear on screen). Then after 1min the backlighting turns off and the screen is completely dark. I use this in a cinema setup.
diisign.com
Yes, that is how it is!
Excellent! this is great new :)
