Hello everyone! After long time finally I found Form 1 headphones in very good technical condition...but not in a cosmetic one. OK-the cleaning would be not a problem, but there are no foam pads on both sides.
Can somebody advise me how can I find these foam pads? I'm afraid our local dealer in Bulgaria doesn't have them.
Thank you in advance!
Mitko
Hello Mitko,
I am afraid the short answer is: You can't. They are not manufactured anymore and unless you can find a stash on eBay or similar, your best choice is to make your own...(I am in a similar situation and you can imagine my disappointment when I realised that they were more or less useless...)
Thank you for your answer Milton! I suspected that , I'm not disappointed, just probably eager now to make them by myself
I know-Form 1 is probably the best headphones that B&O made...and probably they can beat some of others brands expensive models
There's another thread just for you
--mika
Faaaaaaaaantastic!!!!Thank you all!!!!!
I have a mint condition set of Form 1 headphones with perfect foam pads, and I've got a friend who does 3D printing. I'll ask if he can replicate the foam pads with his machine. I'm not sure if he can print objects out of that same type of foam, though.
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Hungedu: I have a mint condition set of Form 1 headphones with perfect foam pads, and I've got a friend who does 3D printing. I'll ask if he can replicate the foam pads with his machine. I'm not sure if he can print objects out of that same type of foam, though.
That's very interesting, please post some pictures if you can, thanks!
Brengen & Ophalen
