Hello,
Unfortunately the bottom tweeter on one of my beovox c40 speakers is not working now. I opened it up and can't see anything obviously wrong (like wiring) so I'm unsure of what to do. It's an audax HD 9*8 D 25 8-9 ohms. Does anyone know of a decent replacement or possible common problem/diagnosis for these speakers.
Thanks.
I never saw an Audax tweeter in one of these.Can you tell me the serial number of that speaker ?
think it's 2389. I'll try and get some images posted.
images:
IMG_0368.JPG.aspx
IMG_0369.JPG.aspx
I found this:
http://www.bonanzamarket.co.uk/listings/Bang-Olufsen-Spare-part-8480159-Dome-Tweeter-for-Beovox-CX50-CX100-C30-C40-C75/79665521
Yes, that's my listing.But it doesn't seem to fit your speaker unless yours were modified at some point.
Type 6322 should have a SEAS tweeter.Type 6324 early version should also have a SEAS but only up to s/n 2481001, hereafter a Philips.
My guess is that yours originally had a SEAS but it was replaced at some point.Have you checked the other speaker to see what's fitted there ?
The other tweeter is the same, strange?
Did you find the serial number ?
hd9x8d25 - I found some info here:
http://www.audax.com/archives/hd9x8d25.jpg
http://www.audax.com/archives.php
Did you find the serial number of your C40 Speakers.
ah sorry. 1803084.
Looks very much like the SEAS so will probably be original.The serial number points to very early production individuals.
Thanks, I've found a replacement coil here:
http://www.falconacoustics.co.uk/audax-rw025a0-voice-coil-tw025a0-hd100d25-hd9x8d25-tweeter.html
Would this be all that is needed?
Check continuity on your own tweeter first.Use an ohmmeter across the terminals (tweeter out of speaker circuit).Anything above 10-12 Ohms points to a bad coil.
Thanks for help. It is a bad coil.
