c40 tweeter
This post has 14 Replies | 0 Followers
woop
Posts 22
woop Posted: Tue, Oct 9 2012 9:24 PM
Hello,
Unfortunately the bottom tweeter on one of my beovox c40 speakers is not working now. I opened it up and can't see anything obviously wrong (like wiring) so I'm unsure of what to do. It's an audax HD 9*8 D 25 8-9 ohms. Does anyone know of a decent replacement or possible common problem/diagnosis for these speakers.
Thanks.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Oct 9 2012 9:39 PM
I never saw an Audax tweeter in one of these.
Can you tell me the serial number of that speaker ?
woop
Posts 22
woop replied on Tue, Oct 9 2012 10:24 PM
think it's 2389. I'll try and get some images posted.
woop
Posts 22
woop
Posts 22
woop replied on Wed, Oct 10 2012 8:37 PM
I found this:
http://www.bonanzamarket.co.uk/listings/Bang-Olufsen-Spare-part-8480159-Dome-Tweeter-for-Beovox-CX50-CX100-C30-C40-C75/79665521
Dillen
Posts 13,191
Dillen replied on Wed, Oct 10 2012 8:58 PM
Yes, that's my listing.
But it doesn't seem to fit your speaker Confused unless yours were modified at some point.
Type 6322 should have a SEAS tweeter.
Type 6324 early version should also have a SEAS but only up to s/n 2481001, hereafter a Philips.
My guess is that yours originally had a SEAS but it was replaced at some point.
Have you checked the other speaker to see what's fitted there ?
woop
Posts 22
woop replied on Wed, Oct 10 2012 10:10 PM
The other tweeter is the same, strange?
Dillen
Posts 13,191
Dillen replied on Thu, Oct 11 2012 7:00 AM
Did you find the serial number ?
woop
Posts 22
woop replied on Thu, Oct 11 2012 9:09 PM
hd9x8d25  - I found some info here:
http://www.audax.com/archives/hd9x8d25.jpg
http://www.audax.com/archives.php
Søren Mexico
Mexico City
Posts 6,411
Did you find the serial number of your C40 Speakers.
woop
Posts 22
woop replied on Thu, Oct 11 2012 9:42 PM
ah sorry. 1803084.
Dillen
Posts 13,191
Dillen replied on Thu, Oct 11 2012 10:07 PM
Looks very much like the SEAS so will probably be original.
The serial number points to very early production individuals.
woop
Posts 22
woop replied on Thu, Oct 11 2012 10:16 PM
Thanks, I've found a replacement coil here:
http://www.falconacoustics.co.uk/audax-rw025a0-voice-coil-tw025a0-hd100d25-hd9x8d25-tweeter.html
Would this be all that is needed?
Dillen
Posts 13,191
Dillen replied on Fri, Oct 12 2012 6:35 AM
Check continuity on your own tweeter first.
Use an ohmmeter across the terminals (tweeter out of speaker circuit).
Anything above 10-12 Ohms points to a bad coil.
woop
Posts 22
woop replied on Sat, Oct 13 2012 12:01 PM
Thanks for help. It is a bad coil.
Page 1 of 1 (15 items) | RSS
