There are some discussions about the batteries for Beolink 7000.
I have still some NiCad batteries left, but in time I am running out of these batteries. Buying new ones is not possible anymore.
What is the alternative? I red about NimH batteries on this forum and I seems not a got alternative.
Does anyone has a solution for this problem?
Maby someone has build new electronics into the charger for NimH batteries?
Well it is a nightmare when my Beolink 7000 will end up in the museum when running out of batteries.
Piet
I bought some batteries on ebay from beovienna and they seem to work fine, Someone I know bought the individual batteries and soldered them together and that also worked.
I am trying to get batteries for my Beo5 without success at the moment, any ideas?
Regards
Paul
Beovienna still have replacement batteries for the Beolink 7000.
See: https://www.ebay.com/itm/Akkupack-Battery-Pack-BeoLink-7000-original-BANG-OLUFSEN-B-O-/171137440535?hash=item27d8961b17
/steffen
patcherley: I am trying to get batteries for my Beo5 without success at the moment, any ideas?
You need two 4/5 AA 1.2 V akkus. They are usually made for shavers. Try the search function here on Beoworld.
I just installed thes ones in may Beo5 and my Beo6:
https://www.amazon.de/Panasonic-HHR-120AA-BK-120AA-Ni-MH-L%C3%B6tfahne/dp/B0197ZYG5I/ref=sr_1_fkmr0_1?s=ce-de&ie=UTF8&qid=1518708371&sr=1-1-fkmr0&keywords=Panasonic+HHR-1200
Stefan
Thanks Stefan, just ordered some.
For the Beolink 7000, here in the states, buying new NiCd AA batteries is still possible. Digi-Key, for example, even have pre-soldered AA 5-packs, which is what I used last time I re-did mine. DK part number SY115-F051-ND. BeoVienna's look slightly different, with the final solder tabs angled-in which probably makes them exact-fit. (I was soldering anyway and probably attached a wire to the end-tabs. That will make it easier next time because I can just cut it and don't have to re-solder on the original board.) USD15 instead of EU36. No knock against BeoVienna though; I bought his Lithium memory-backup battery for the BeoLink 7000, which is simply a CR2032 -- because the placement is tight, and in that case I didn't want to worry about whether the solder-tabs from the supply house were right.
Thanks Steffen. I just ordered the batteries.
