Beolink 7000 batteries
This post has 11 Replies | 0 Followers
Piet
Noordwijk, The Netherlands
Posts 26
Piet Posted: Thu, Feb 15 2018 10:43 AM
There are some discussions about the batteries for Beolink 7000.
I have still some NiCad batteries left, but in time I am running out of these batteries. Buying new ones is not possible anymore.
What is the alternative? I red about NimH batteries on this forum and I seems not a got alternative.
Does anyone has a solution for this problem?
Maby someone has build new electronics into the charger for NimH batteries?
Well it is a nightmare when my Beolink 7000 will end up in the museum when running out of batteries.
Piet
patcherley
Posts 67
patcherley replied on Thu, Feb 15 2018 12:10 PM
I bought some batteries on ebay from beovienna and they seem to work fine, Someone I know bought the individual batteries and soldered them together and that also worked.
I am trying to get batteries for my Beo5 without success at the moment, any ideas?
Regards
Paul
skolesen
Hvidovre, Denmark
Posts 34
skolesen replied on Thu, Feb 15 2018 2:13 PM
Beovienna still have replacement batteries for the Beolink 7000.
See: https://www.ebay.com/itm/Akkupack-Battery-Pack-BeoLink-7000-original-BANG-OLUFSEN-B-O-/171137440535?hash=item27d8961b17
/steffen
stefan
200 miles from Struer
Posts 2,920
stefan replied on Thu, Feb 15 2018 3:26 PM
patcherley:
You need two 4/5 AA 1.2 V akkus. They are usually made for shavers. Try the search function here on Beoworld.
I just installed thes ones in may Beo5 and my Beo6:
https://www.amazon.de/Panasonic-HHR-120AA-BK-120AA-Ni-MH-L%C3%B6tfahne/dp/B0197ZYG5I/ref=sr_1_fkmr0_1?s=ce-de&ie=UTF8&qid=1518708371&sr=1-1-fkmr0&keywords=Panasonic+HHR-1200
Stefan
patcherley
Posts 67
Thanks Stefan, just ordered some.
Paul
patcherley
Posts 67
Paul
patcherley
Posts 67
Paul
patcherley
Posts 67
Paul
patcherley
Posts 67
Paul
patcherley
Posts 67
Paul
trackbeo
Posts 644
trackbeo replied on Thu, Feb 15 2018 7:16 PM
For the Beolink 7000, here in the states, buying new NiCd AA batteries is still possible.  Digi-Key, for example, even have pre-soldered AA 5-packs, which is what I used last time I re-did mine.  DK part number SY115-F051-ND.  BeoVienna's look slightly different, with the final solder tabs angled-in which probably makes them exact-fit.  (I was soldering anyway and probably attached a wire to the end-tabs.  That will make it easier next time because I can just cut it and don't have to re-solder on the original board.) USD15 instead of EU36.  No knock against BeoVienna though; I bought his Lithium memory-backup battery for the BeoLink 7000, which is simply a CR2032 -- because the placement is tight, and in that case I didn't want to worry about whether the solder-tabs from the supply house were right.
Piet
Posts 26
Piet replied on Fri, Feb 16 2018 8:01 AM
Thanks Steffen. I just ordered the batteries.
Piet
Page 1 of 1 (12 items) | RSS
