Please test your Beoplay H9i
This post has 48 Replies | 2 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
Same issue with the new ones Sad
Geoff Martin
Struer, Denmark
Posts 672
Please make sure that your headphones have the latest software. It's currently v. 5.0.4
This can be done either via the Bang & Olufsen app, or via the software updater (for Mac or PC) available on this page:
https://www.beoplay.com/en/support/product-support/support-beoplay-h9i
Note that, to update using the Mac/PC version, you'll need a USB cable.
Cheers
-geoff
leosgonewild
Helsinki, Finland
Posts 2,373
Ok. It looks like they only updated to 5.0.3.
Will update later today and give feedback. Smile
Jon
Hampshire, United Kingdom
Posts 241
Jon replied on Mon, Oct 15 2018 9:13 AM
leosgonewild:
I’d recommend doing it via a computer, when I got my terracotta H9i I tried updating in the app twice and both times I looked at the app later and it still said 5.0.3 and was prompting me to update.
leosgonewild
Helsinki, Finland
Posts 2,373
Geoff Martin:
Cheers
-geoff
Sorry, Geoff. The issue is still present with 5.0.4.
Are you able to do something with the software or should I return them?
Geoff Martin
Struer, Denmark
Posts 672
I can't diagnose exactly what the problem is with your headphones. However, we did a tuning update that should take care of the "Diana Krall" issue.
If the problem is different from this, then I'll need more info about it, and then I can try to duplicate your problem on the reference pair that we have in Struer...
Cheers
-geoff
leosgonewild
Helsinki, Finland
Posts 2,373
It’s the Diana Krall issue.
I am using H6 mk1 as reference here.
Svenni
Berlin, Germany
Posts 48
Svenni replied on Tue, Oct 16 2018 2:52 PM
Reading through this thread makes me even sadder that the H6 was discontinued. The 2nd gen was one of the best portable closed back headphones you can get.
Beoplay A2
Beoplay Earset
Beoplay H6 (Gen 2)
Beoplay S3 (pair)
Beoplay S8
Beovox CX50 (2 pairs)
Beovox RL 6000
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Sun, Mar 31 2019 5:22 PM
What is latest said on this topic, has firmware updates been issued to solve the ANC sound issues?
Page 2 of 2 (49 items) < Previous 1 2 | RSS
