Hello everyone first post time!
Had the BM5000 (1984) since new. Working OK until a few weeks ago. Had an intermittent power cut - off and on a few times then off. The unit was on standby at the time and fed from a UPS with inbuilt power surge protection and EMI/RFI filtering.
Now it won't turn on. The standby LED is lit. Panel OPEN function inoperative. Pressing MUTE/PLAY causes the standby LED to flash on/off. There is a sound from the speakers at power on and off as normal. And the relay in board 3 works OK. All voltages from the PSU are present within +/- 10%.
I am thinking it may be the processor board.
Any help or advice appreciated.
Thank you!
In case anyone is following this, I replaced the processor board with one from another faulty unit (with PSU problems).
It now works 100% again
I like to keep the old stuff going.....
I have a Crown power amp in my studio that I bought 50 years ago. Never needed any attention...yet!
Crown DC-300A?
D150...I use it with 15" Tannoy Classic dual concentrics which are very sensitive. Thus saving power and the planet
I would suggest turning power off at the plug whenever possible in order to protect the vulnerable BM5000 processor from damage.
I have now repaired 2 faulty BM5000 processor boards simply by replacing 4C59 33uf/6v axial electrolytic capacitors at a total cost of £1.00
The reset was non-functional in each case.
Both old capacitors had exploded!
BTW both boards used coin cells for memory backup. Type CR2430.
