Beomaster 5000 problem
Bangoid
Scotland UK
Posts 11
Bangoid Posted: Tue, Feb 20 2018 4:54 PM
Hello everyone first post time!
Had the BM5000 (1984) since new. Working OK until a few weeks ago. Had an intermittent power cut - off and on a few times then off. The unit was on standby at the time and fed from a UPS with inbuilt power surge protection and EMI/RFI filtering.
Now it won't turn on. The standby LED is lit. Panel OPEN function inoperative. Pressing MUTE/PLAY causes the standby LED to flash on/off. There is a sound from the speakers at power on and off as normal. And the relay in board 3 works OK. All voltages from the PSU are present within +/- 10%.
I am thinking it may be the processor board.
Any help or advice appreciated.
Thank you!
Bangoid
Scotland UK
Posts 11
Bangoid replied on Fri, Mar 9 2018 6:56 PM
In case anyone is following this, I replaced the processor board with one from another faulty unit (with PSU problems).
It now works 100% again Smile
Saint Beogrowler
Saint Paul
Posts 780
Nice work. I really like the BM5000
Bangoid
Scotland UK
Posts 11
Bangoid replied on Sat, Mar 10 2018 4:48 PM
I like to keep the old stuff going.....
I have a Crown power amp in my studio that I bought 50 years ago. Never needed any attention...yet!
MediaBobNY
Greenwich Village, NYC
Posts 1,106
Crown DC-300A?
Bangoid
Scotland UK
Posts 11
Bangoid replied on Sun, Mar 11 2018 7:54 AM
D150...I use it with 15" Tannoy Classic dual concentrics which are very sensitive. Thus saving power and the planet Smile
Bangoid
Scotland UK
Posts 11
Bangoid replied on Fri, Mar 16 2018 9:56 AM
I would suggest turning power off at the plug whenever possible in order to protect the vulnerable BM5000 processor from damage.
Bangoid
Scotland UK
Posts 11
Bangoid replied on Sat, Apr 28 2018 3:15 PM
I have now repaired 2 faulty BM5000 processor boards simply by replacing 4C59 33uf/6v axial electrolytic capacitors at a total cost of £1.00 Smile
The reset was non-functional in each case.
Both old capacitors had exploded!
BTW both boards used coin cells for memory backup. Type CR2430.
Page 1 of 1 (8 items) | RSS
