Popping Beolab 5
YannChris
Larmor Plage - France
Posts 232
YannChris Posted: Sat, Oct 13 2012 1:59 PM
Hello Beoworlders,
My beloved Lab5 show a strange behaviour since a few weeks.
When turning off the system, the discrete relay "clicks" are replaced by huge "pops".
It also happen from time to time when I use the AV.. command.
You have all guessed that I need help, or at least a few tips to test what's happening.
The nearest dealer is 100 miles away, so I would prefer to be sure it's not a problem that I can solve by myself.
Thanks by advance and kind regards,
Yann.
Living Room   BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge  Beolink Passive - Cabasse Clipper - Beo4      Kitchen  BL3500 - Beolink 1000
Bedroom    BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge   BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study    BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sat, Oct 13 2012 2:23 PM
Hi Yann, is it happening on both or just 1 ?  Are you using just a two pin plug into your mains electricity ? Guessing bl5's have an earth pin ? If is only one speaker  i would suspect your speaker cable. Best to eliminate the obvious first.
stefan
200 miles from Struer
Posts 2,920
stefan replied on Sat, Oct 13 2012 4:32 PM
Have you made some changes in your setup right before the behaviour started?
Are your BL5s connected to a BV?...Settings correct?Do have sound on both BLs? ...Green light?
Does the fault only appear on one BL?
First I`d try is to disconnect mains, Powerlink and spdif (if connected) for five - ten minutes and then reconnect.
I had a similiar problem with one of my 5s years ago, but sometimes even no sound....
Stefan
YannChris
Posts 232
YannChris replied on Sun, Oct 28 2012 8:53 PM
Hello,
I come back after some testing:
I did not really noticed when the problem appeared, nothing has changed in my setup.
BL5 are connected to BV9, settings OK (same on BV and Labs).
They are not earthed (by design, the power plugs do not have an earth connexion).
Only one BL5 is affected,
The default appears with or without SP/DIF, either on audio or video sources.
I changed the Powerlink cable, the default remains.
If I switch the systen off after a short time (5/10 minutes), no "pop".
If I switch the system off after a longer delay, the "pop" occurs.
It looks like the default is located in the Lab5. Any clue?
Thanks for your help,
Yann.
MarcIvarsson
Posts 5
Het. Also have problems with popping sounds, but this only happens when I start upp the system and only on one lab5. The popping sound emerges shortly after the red light changes to green on the speaker. I wonder if it is the same popping sound you have trouble with?
stefan
Posts 2,920
stefan replied on Mon, Oct 29 2012 11:21 AM
YannChris:
Agree. Sounds like you both have faulty electronics in one of your BL5s.
As said before I had the same (?) popping sound in one of my BL5s years ago.
The complete chassis was replaced by an electronics kit - Eprom of the faulty chassis was set to the new kit to match the other BL5.
My BL5s sound exactly as before, the fault never appeared again.
The exchange kit from Beo was 250 Euros, the labour of my Beo store was 0 Euro...:)
They said, BL5 should`t get faulty after a few years, so they wouldn`t charge me for the repair. I took it as a special kind of "warranty"
Stefan
YannChris
Posts 232
YannChris replied on Mon, Oct 29 2012 8:01 PM
Stefan,
It sounds as you are a lucky man.
I wonder if this type of "special warranty" is still alive in nowadays B&O world.
Thanks for your help.
Yann.
Page 1 of 1 (7 items) | RSS
