Hi, does anyone know where i can purchase a centering tool to adjust the cd mechanism on the beosound 9000?
At the dealer’s?
Just a flat screwdriver will do.
Beobuddy:Just a flat screwdriver will do.
Yep, just peek inside to see where the arrow is pointing and know where you need it to be pointing before making the adjustment so you know which orientation the 9000 will be placed. Especially since the flathead screwdriver doesn't have the arrow shape the original red tool has.
Thanks for the advice, will try it with the screwdriver when i get home.
Ive just removed to 2 black caps off the back, but there is nothing there, i can see the class of the front panal, is there something missing? Ive had the beosound playing on the wall horizontally and laid flat on a tv unit, it works perfectly laid down, but when on the wall allthough everything plays, i can hear a scrapping sound like the cd is catching on something.
Maybe it would help if the cd mechanisim was in the correct place ha. All sorted now.
