centering tool for beosound9000
foolsgold1999
Posts 5
foolsgold1999 Posted: Tue, Feb 27 2018 1:49 PM
Hi, does anyone know where i can purchase a centering tool to adjust the cd mechanism on the beosound 9000?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Tue, Feb 27 2018 2:37 PM
At the dealer’s?
Just a flat screwdriver will do.
Sal
California, USA
Posts 1,197
Sal replied on Tue, Feb 27 2018 2:56 PM
Beobuddy:
Yep, just peek inside to see where the arrow is pointing and know where you need it to be pointing before making the adjustment so you know which orientation the 9000 will be placed. Especially since the flathead screwdriver doesn't have the arrow shape the original red tool has.
foolsgold1999
Posts 5
Thanks for the advice, will try it with the screwdriver when i get home.
foolsgold1999
Posts 5
Ive just removed to 2 black caps off the back, but there is nothing there, i can see the class of the front panal, is there something missing? Ive had the beosound playing on the wall horizontally and laid flat  on a tv unit, it works perfectly laid down, but when on the wall allthough everything plays, i can hear a scrapping sound like the cd is catching on something.
foolsgold1999
Posts 5
Maybe it would help if the cd mechanisim was in the correct place ha. All sorted now.
Page 1 of 1 (6 items) | RSS
