BLC Dead?
chucky
Posts 331
chucky Posted: Fri, Mar 2 2018 10:35 PM
Hi try to set up my BLC as audiomaster connected to a beosound in a mainly ML setup. BV 7 as Video master, Beosound Core connected in the kithen with beolab 4000. BLC Stand alone but later connected as active kit in the garage. Connected on CAT 7 is around 30 meters away. I can reach all IP Wired.
It seems I do not have an audiomaster, i cannot connect and when i do in the garage I get a video source.
Setup as master, reffering to the right source eg on ML RADIO to TuneIn.
I have reset the power a few times because this seems to work with elephant however no result.
I can also not join the BS Core in the kitchen.
Am I doing something wrong or is it dead? also have a BLGW but that should not matter ?
Tx Chucky
Soren
Denmark
Posts 115
Soren replied on Sat, Mar 3 2018 7:24 AM
Hi
When you write “BLC as audiomaster connected to a beosound“.... Does that mean that you also have an other Beosound (Masterlink Version) connected? Or is it just the Beosound Core
Søren
chucky
Posts 331
chucky replied on Sat, Mar 3 2018 8:01 PM
Took out the beosound 3000 just the Core remaining with the NL/ML LINK Converter
Tx chucky
Soren
Denmark
Posts 115
Soren replied on Sat, Mar 3 2018 10:14 PM
You Can only have one AudioMaster and one Videomaster in a Masterlink system, that means that if you have the Beosound 3000 connected in option 0,1 or 2 you must setup the NL/ML converter as A.slave.
Page 1 of 1 (4 items) | RSS
