Opening a Beovox S45?
This post has 9 Replies | 0 Followers
Agent00soul
Posts 15
Agent00soul Posted: Sat, Oct 13 2012 8:31 PM
Hi all. I just received a pair of Beovox S45 (mark I). I'm going to give them a checkup and cleaning etc. So how do you open them up with the least risk of damage?
Another question: Where can you buy the female DIN loudspeaker connectors that fit the Beovoxes? I have a couple of cables for my CX50s and CX100s but the S45s came without cables, unfortunately.
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Oct 13 2012 10:17 PM
Take the bass unit out - it is a nice SEAS unit with multiple screws. You can access the cross over that way.
Peter
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Oct 14 2012 11:40 AM
Peerless, actually. Wink
And glue the magnets while you have the woofers out.
Bob
Charente, France
Posts 418
Bob replied on Sun, Oct 14 2012 11:51 AM
Hi, how to get to it Peter already told you, Martin gave you advice on what to do with the woofers and the connectors you can get at B&O dealer or good electronic store quiet cheaply. they're just standard DIN 2 pin speaker connectors, the large pin be N ;)
regards
bob
Don't worry - be Happy
Agent00soul
Posts 15
So you start by prying the front off? Any special technique for that? How is it held in place?
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Oct 14 2012 12:53 PM
Dillen:
My mistake - is it the S75 which is SEAS?
Peter
Dillen
Posts 13,191
Dillen replied on Sun, Oct 14 2012 2:43 PM
Yes, Laughing
The fronts are held in place by small pegs. They can bind immensely.
Pull right outwards on the thick part at the top, work your way carefully downwards.
There are six pegs in total, one in each corner plus two down the center.
Agent00soul
Posts 15
Thanks Martin. I managed to get it off without damage to the front or the aluminum edge. A steel ruler is your friend.
The crossover has three 16 uF/40V capacitors. Is it a good idea to use the bipolar electrolytics, that are available nowadays?
Agent00soul
Posts 15
No reply about the bipolar caps, but a forum search seems to indicate that they are recommended.
Søren Mexico
Mexico City
Posts 6,411
Agent00soul:
Use only bipolar caps in crossovers, if you cant get the right sizes (uF) put 2 in parallel, or get a set from Martin with instructions.
Page 1 of 1 (10 items) | RSS
