beogram 9500 connection to amplifier and MMC2 questions
This post has 8 Replies | 2 Followers
beogram9500fan
Bonn, Germany
Posts 1
beogram9500fan Posted: Sat, Mar 3 2018 2:51 PM
I have inherited the great beogram 9500 with a MMC2 cartridge.
Three questions I need help with:
a. Is the MMC2 an MM or MC cartridge
b. If I want to connect the beogram 9500 to an amplifier with MM/MC input (not B&O) using an adapter from DIN to cinch the soun dis horrible (both variants MM and MC). Long time ago I heard the DIN cables have a different connection order than standard DIN - might this be the issue?
c. In case the needle and/or cartridge need to be renewed, does anyone no sources where to buy those - or service points in Germany, Cologne/Bonn area?
Any feedback and support is very much appreciated!
Many thanks in advance!
W.Frankenberg / Gandalf
Heilbronn / Germany
Posts 290
a-This cartridge is moving coil  mc type.
b-you neef a preamplivier with riaa encoding!
c-have a look to : schallplattennadeln.de
The MMC2 is a functional replacement for the MMC1 MMC3 MMC4 and MMC5 (MMC1 is top of the line, MMC5 is bottom.) The needle on your existing cartridge is not user replaceable. Keep your old one in case you ever want the tip replaced someday at about 2/3rds the cost of a new one.
This wonderful cartridge will work in any of the following Bang & Olufsen models:
BeoCenter:
2200
7007
7700
BeoGram
RX
RX2
TX
TX2
1800
2000
2404
3000
3300
3500
4500
5000
5005
5500
6002
6500
7000
8002
8500
9000
9500
wilfried
Heilbronn / Germany
Posts 290
sorry, of course the MMC 1-5 systems are moving magnet systems
wilfried
AdamS
Posts 373
AdamS replied on Mon, Mar 5 2018 1:03 PM
The MMC2 is NOT an MC cartridge, nor are any of B&O's MMC2x or MMCx cartridges. 'MMC' stands for Moving Micro Cross and they are actually closest to a Moving Iron design.
However, from a phono stage compatibility point of view, they should be treated as MMs.
leosgonewild
Helsinki, Finland
Posts 2,373
buy the riaa-kit from soundsheavenly and connect it to a regular aux input on your amplifier.
Saint Beogrowler
Saint Paul
Posts 780
AdamS:
Yes MM for B&O.
But, I think I have one of the only real MC B&O cartridges ever made.
Now that I'm done showing off.
Can you describe the kind of horrible sound? It could be a dirty stylus or wornout stylus or bad suspension on the cartridge.
AdamS
Posts 373
AdamS replied on Mon, Mar 5 2018 6:19 PM
Now that's something I've never seen before! How does it sound?
Saint Beogrowler
Saint Paul
Posts 780
AdamS:
It sounds fuller and a little bIt more detailed than the original MMC1 or my rebuilt MMC2.
I haven't measured but it is a pretty low output cart compared to many other MC carts I've used. Running it with the soundsmith MC preamp now, I was using a SUT and a MM soundsmith preamp but I couldn't get the capacitance right.
It really shows off how quiet the Bg8002 is compared to the later linear trackers or my rx2.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
leogoeswild:
Thanks leogoeswild!
Yes, this pre-amp kit includes all cables and instructions, this is correct to link the MMC (Moving Micro Cross, a variation of the moving magnet design) cartridge in your Beogram to any amplifier that doesn't already have a phono pre-amp stage fitted:-
https://soundsheavenly.com/beogram-record-players/pre-amp-bundle-for-bo-beogram-and-all-turntables – please choose the “Twin RCA plugs” output option for a non-B&O amplifier.
I was really interested to see the special "one-off" moving coil B&O cartridge in Saint Beogrowler's pictures, I am very jealous! Geeked
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (9 items) | RSS
