hi,
since friday I have no cover-art when playing from Deezer with the B&O app. Does anybody experience the same problem?
best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Beovision Elclipse 55”, Beolab 8000, Beoplay A6 and M5
BeoNut since '75
no covers here either (Deezer Hifi (Flac) used with Moment and V1)
Same for me, using BS1.
Yann.
Living Room BV Eclipse - BS Core - BL5 - BL8000 - LC2 x2 - Beo6
Lounge Beolink Passive - Cabasse Clipper - Beo4 Kitchen BL3500 - Beolink 1000
Bedroom BV9 - BL6000 (Thks Botty) - Beotime - LC2 - Beo5
Garden Lounge BC9000 - BG 6006 - BL4500 (Thks Botty) - Playmaker - Beolink 1000
Study BS1 - ML/NL Converter - BL2500 - Beo4 - Form 2 (Tks Botty) - Beoplay P2
Same here on both my Moment (non-beta) and M3. Using latest beta of the app, through Test Flight, and Deezer Hifi. I restarted my iPhone, and the problem disappeared. Didn't take long before it was back, though.
-h.
I have the same problem when using Deezer with Eclipse. There has not been any softwareupdate in the Eclipse when this problem occured. So my conclusion is that it is a problem with Deezer and not with B&O software in there products. I noticed it two days ago. Earlier in the week it worked.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
elephant:I don’t. My App is using Deezer HiFi (FLAC) and controlling a Core. (Just tested it and skipped through 4 covers)
I did not have the problem 36 hours ago ... and now I do !
However it appears to be intermittent .. and some times a track starts with cover art and then it disappears ! (or turns all black if you prefer after all it was "Back Magic Woman" I was playing at the time).
Hi, I notice exactly the same as Mbolo01.
I have complained to Beocare this problem. I hope all of You will complain to Beocare so the problem get solved soon.
/Martin
Martin:I hope all of You will complain to Beocare som the problem get solved soon
Hiort:Got a message that this indeed is a Deezer issue and will be solved on Monday.
Unfortunately it has not been solved.
mbolo01:Unfortunately it has not been solved. BS Moment, BL 18, BL 19, A6, M5, A1, H5
Hi all
Deezer was delayed with their fix and couldn't deploy Monday. I'm in contact with them and their new rollout time is tomorrow. I'm sorry for the delay.
Br
Thomas Andersen, Bang & Olufsen
Deezer didn't make the release monday as expected. I have been in contact with them and they promise to roll out tomorrow. Sorry for the delay.
Hi Thomas,
Great Thanks for the fast fix from B&O regarding this issue. We dont want another "Beosound 5-spotify" thing with Deezer-integration in B&O:s products.
Best RegardsMartin
Hi
It's not fixed on my system (Wednesday evening Sydney time). I'm now not getting artwork either, rather a black area where artwork should be.
Im using the beta software.
Regards
David
Beovision 8-40, Beocentre 6-26, Beocentre 2, Beolab 9's, Beogram 7000, Beogram 9500, Beo 5, Beolit 1000, 800, 700, 600, 400, Beocom 6's, Beotalk 1200
Im still having the 'no artwork' issue on my system using the App.
Its Wednesday evening Sydney time.
David Coyne: Hi Im still having the 'no artwork' issue on my system using the App. Its Wednesday evening Sydney time.
Seems to be back, just now!
Henrik:Seems to be back, just now! -h.
mbolo01:Cover are now working for me too, including for Hiort’s track BS Moment, BL 18, BL 19, A6, M5, A1, H5
I also confirm that cover-art now works perfect.
@Martin
Perhaps you should add ‘Solved’ to the title of the thread - since the issue now seems to be solved.
