Hi guys,
At the moment in my 'cinema' room I've a quartet of lab 5's (and some 17's) playing with an Avant (first gen).
I've gotten a super upgrade deal from my dealer to replace the two 'front' Lab 5's with 50's.
Anyone have any experience with mixing 50's into a surround setup? Should I add a core for stereo music too?
TIA!
Stephen
Some speakers will be room compensated, others won't. To get the best soud from BL50 you have to use the high latency mode and that could give you problems with lip sync.
If your TV has a lipsync adjustment, then you'll be fine.
Thanks! Will look into the options I have with the avant!
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
boskonay: Should I add a core for stereo music too? TIA! Stephen
I certainly would consider this!
There are (at least) two ways of connecting a BS Core to the BL50’s.
For one you could set it up as a integrated NL device of the BV Avant.
This would give you instant access to some of the sources of the Core (by using the BeoRemote One),
You can assign these sources to a Speaker Group consisting of the two BL50’s (including your choice of Preset for them/high latency mode etc).
The BL50’s would then be connected via PL (or WPL) to your Avant.
That would be the ‘easy-to-handle-way’ of doing it.
One drawback however, the tv will have to turn on for this!
Alternatively you could connect the output of the BS Core directly to the Coax-in of the BL50 combo - just like you would with any ‘ordinary’ external device.
See the User Guide for this - including managing priority of the external sources.
This way you can use the BL50’s without having to turn on the tv.
But....you would basicly have to use the Bang & Olufsen app for controlling (the sources of) the BS Core.
I am pretty sure you will adore these speakers - you won’t miss your (front) BL5’s ;-)
However, to explore the full potential of the BL50 you will have to learn how to use them.
Much more possibilities there than with the BL5s.
Thanks all!
the BeoLab 50's and a core are being installed on the 10th April next, and configured so they are the front left/right of with the Avant, but also as a pair with the core for music. Can't wait!!
Will post a pic once they are in :)
My main 'worry' now is that the sound processing in the Avant (for the more recent) format's can be a little bit rough around the edges, and there is of course no HDR or atmos, etc, support at all :)
Hopefully B&O will give us a nice LG 77 with all the bells soon!
boskonay:there is of course no HDR or atmos, etc, support at all :)Hopefully B&O will give us a nice LG 77 with all the bells soon!
BeoNut since '75
elephant: Do you mean this year’s LGs (eg C8?) and their latest CPU will have the power/ speed to process HDR / ATMOS ? Rumour or Fact ?
Rumour or Fact ?
As for Atmos (I guess we are talking sound here) - yes the new 2018/LG’s will be able to bitstream Atmos.
However that won’t help us much since there is no current SoundCenter with support for Atmos and probably nothing coming soon.
By the way - did you know, that the LG’s only support Atmos encoded in Dolby Digital Plus, not in Dolby TrueHD - so no lossless sound format there!
Have a look here for the 2018/LG’s:
http://www.avsforum.com/lg-2018-tv-reviewers-workshop/
