I've recently bought a Beocenter AV5 and upon connecting a source over SCART I've noticed the Geometry is off. I've managed to correct this to some extent but I'm left with some minor pin cushion effect at the bottom of the screen. It's nothing major and Its only really noticeable when a flat line is displayed across this area of the screen.
Have searched high and low for a service guide which may suggest a baseline setting to work from but unfortunately, I've not found anything. Does anyone happen to know of any documentation I can refer to? Or better still, if anyone has a set that displays in 4:3 (shows as Format 1 on the led panel) would it be possible to take a picture of the current settings your TV has?
At this stage only a very minor tweak is needed or I need to flatten all the settings out and start from scratch so any guidance would be much appreciated.
I have a fully functional set, what do you need on that "screen shot" ?
Hi Beovox, a screenshot of the following values:
Refresh my mind,- how do I get to that menu?
Select a channel you have mapped to an AV socket, press menu then enter 0, 0, Go. Should open the service menu if you have the right firmware.
As requested
Let me know if I can be of further assistance.
Thanks Beovox, exactly what I was after. I wasn't too far off but I've still got the pincushion effect at the bottom of the screen so suspect I may have some components that are on their way out. Appreciate you taking the time to grab the geometry pic though. :)
