B&O Monitor Service - Geometry Settings
This post has 6 Replies | 0 Followers
Caseh
Posts 4
Caseh Posted: Sat, Mar 17 2018 7:47 PM
I've recently bought a Beocenter AV5 and upon connecting a source over SCART I've noticed the Geometry is off. I've managed to correct this to some extent but I'm left with some minor pin cushion effect at the bottom of the screen. It's nothing major and Its only really noticeable when a flat line is displayed across this area of the screen.
Have searched high and low for a service guide which may suggest a baseline setting to work from but unfortunately, I've not found anything. Does anyone happen to know of any documentation I can refer to? Or better still, if anyone has a set that displays in 4:3 (shows as Format 1 on the led panel) would it be possible to take a picture of the current settings your TV has?
At this stage only a very minor tweak is needed or I need to flatten all the settings out and start from scratch so any guidance would be much appreciated.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, Mar 17 2018 8:14 PM
I have a fully functional set, what do you need on that "screen shot" ?
Caseh
Posts 4
Caseh replied on Sat, Mar 17 2018 8:40 PM
Hi Beovox, a screenshot of the following values:
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, Mar 17 2018 9:07 PM
Refresh my mind,- how do I get to that menu?
Caseh
Posts 4
Caseh replied on Sat, Mar 17 2018 9:34 PM
Select a channel you have mapped to an AV socket, press menu then enter 0, 0, Go. Should open the service menu if you have the right firmware.
BEOVOX141
Denmark, West
Posts 711
BEOVOX141 replied on Sat, Mar 17 2018 10:25 PM
As requested Smile
Let me know if I can be of further assistance.
Caseh
Posts 4
Caseh replied on Sun, Mar 18 2018 8:07 PM
Thanks Beovox, exactly what I was after. I wasn't too far off but I've still got the pincushion effect at the bottom of the screen so suspect I may have some components that are on their way out. Appreciate you taking the time to grab the geometry pic though. :)
Page 1 of 1 (7 items) | RSS
