How do I add album artwork in Beosound 5?
This post has 19 Replies | 3 Followers
Rikard
Sweden
Posts 218
Rikard Posted: Sun, Oct 14 2012 4:17 PM
I have searched the forum and google - perhaps Im too tired to find my way..
I use a MAC so I cant use beoplayer since it is an windows program..
Im pretty sick n tired of seeing the grey b&o logo.. Soon I will exchange that picture to a pig or something..
So how do I do? :)
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sun, Oct 14 2012 6:28 PM
search for "tag" in App Store
still the Windows app "mp3tag" is the best (my opinion)
Rikard
Sweden
Posts 218
Rikard replied on Sun, Oct 14 2012 6:58 PM
There where some different programs in appstore that can convert mp3s. It looks like the files needs to be on the computer using the program.. I have the music on my bs5. I must be a way to put coverart directly into the bs5..
Paul W
London
Posts 1,810
Paul W replied on Sun, Oct 14 2012 11:53 PM
Hope this helps you Rikard...
http://www.bang-olufsen.com/UserFiles/File/RightNow/Adding_covers_in_BeoPlayer.pdf
Aussie Michael
Melbourne, AU
Posts 3,730
The issue arises around the fact that itunes stores album art in a different directory to the way that the BS5 needs it (windows).
For art to appear on the BS5 there needs to be a jpg in each directory.  This jpg is named folder.jpg
I downloaded a program from the net which was free that did a search based on my music directory and automatically imported the picture jpg and named it correctly.  I will have a search tonight to see if there are any mac equivalents.
I did receive a brochure from my local B&O store and they advise in that how to add cover or album art to your music for BS5.  Is your music stored on a BM5? or in another location?
Rikard
Sweden
Posts 218
Rikard replied on Mon, Oct 15 2012 5:19 AM
Paul - The Beoplayer is a windos based program, there is no version for a mac..
Michael - Yes I have all music stored on the BS5.
DoubleU
Posts 562
DoubleU replied on Mon, Oct 15 2012 6:39 AM
Well, Sonos users have the same problem.. Wink
The easiest way is to install a script in iTunes. This script will pull the artwork that is “hidden” in iTunes, and embed it in the track.
http://dougscripts.com/itunes/scripts/scripts13.php
And go to “Embed Artwork v2.0
Run the script, delete your BM5 library, and re-import your iTunes library.
Another way is to run the script “Save Album Art to Album Folder v4.3”. This script will pull the artwork as “folder.jpg” in the Album folder. With this script you don’t need to delete your BM5 library, but you have to manually drop each folder.jpg file from your iTunes library to your BM5 library. It’s sort of way Michael suggested, but easier.
The first script I suggested seems easier.
Best video’s I found to install the scripts so far are:
http://www.youtube.com/watch?v=oClIT8f6V7E
http://www.youtube.com/watch?v=tJKy2y8p2WM
mbee
Paris, France
Posts 1,842
mbee replied on Mon, Oct 15 2012 6:48 AM
Simply name  the cover image file "folder.jpg" (best result with a 500x500px image) and put it in the album folder.
Fisp
Denmark
Posts 75
Fisp replied on Mon, Oct 15 2012 3:22 PM
I'm on a Mac and besides iTunes I use XLD and Media Rage to add album art and tidy up tags.
Rikard
Sweden
Posts 218
Rikard replied on Mon, Oct 15 2012 5:21 PM
I tried to place album covers with changed names to front.jpg, this did not work out - the covers does not show.
I will try the media rage, otherwise I will have to copy all the collection of 750 albums to another disc/computer, making the changes there, then copying it all back to the BS5 again..
Maybe it is easier to disasemble the BS5 taking the HDD out and making it as an external drive, making the changes there.. But in that case the machine will probably breakdown..
F**k what a time consuming piece of equipment the BS5 is.. It needs alot of work and the B&O guys needs to tell to their customers how to do things the B&O way, since the "normal" way of copying does not work out..
elephant
AU
Posts 8,219
elephant replied on Mon, Oct 15 2012 5:49 PM
Rikard:
Inside each album's folder, the image of the art work needs to be called "folder.jpg" .... maybe "front.jpg" was a typo ?
BeoNut since '75
Fisp
Denmark
Posts 75
Fisp replied on Mon, Oct 15 2012 5:54 PM
Only adding jpg. files in the media folder will not work and no need to take your MB5 apart Unsure
Use Media Rage's "Add Artwork and Folder Icons" and work directly in the "BMShares" folder. It's a bit slow but it works and you will have beautiful cover art on your BM5 Smile
Start with one album to make sure that it works. A good practice is to "Restart music server" from the "Preference" menu when you have made changes.
Rikard
Sweden
Posts 218
Rikard replied on Mon, Oct 15 2012 6:11 PM
I renamed the files to folder.jpg. Now it works! Thx! I will try the Media rage and if it does not work I will go through the folders manually. Anyhow - Im on the right way! THX my fellow beoworlders! :)
f5434964
Austria
Posts 206
f5434964 replied on Mon, Oct 15 2012 7:40 PM
why so difficult?
You need Beoconnect
I'm expecting that you're using iTunes
just drop the music files directly from itunes to the dock icon (beoconnect) - finished
sometimes the *.jpeg files are copied to BM5 - you can delete them - cover art is embedded to the *.mp3 file and will be shown without any *.jpg
regards elmar
Rikard
Sweden
Posts 218
Rikard replied on Mon, Oct 15 2012 8:46 PM
I did just that, in itunes all albums had albumcovers. Then I used Beoconnect to send them to my BS5. Problem was that 80% of the albums where missing when the got to the BS5.. Now when Im looking in the folders there are not many folders with album art.. So it needs manual work..
f5434964
Austria
Posts 206
f5434964 replied on Tue, Oct 16 2012 5:20 AM
ok - sorry - I did not have any problems doing it like that;
Regards Elmar
f5434964
Austria
Posts 206
double post
Rikard
Sweden
Posts 218
Rikard replied on Tue, Oct 16 2012 4:24 PM
The program took information about albums from amazon.com, they did not have the albums I tested so the solution for me is to manually insert the album covers. The easiest/fastest way is to use a searchengine. I tested some sites that were all about albumcovers (no swedish artists) and those sites were really slow so for me google it was faster. It takes alot of time but since it is one of the key features of the BS5 I don´t think I have any option.. On the other hand - it looks good!
Fisp
Denmark
Posts 75
Fisp replied on Tue, Oct 16 2012 4:43 PM
Try one of Doug's scripts, for example:
http://dougscripts.com/itunes/scripts/ss.php?sp=findalbumartwork
OR
scan the covers. (They come out beautifully on the BM5)
Rikard
Sweden
Posts 218
Rikard replied on Tue, Oct 16 2012 5:03 PM
I will definently try the script, I have learned a way to see if and where coveras are needed in the mp3 files. I can write something about this so others dont need to the same research :)
Page 1 of 1 (20 items) | RSS
