Beovox C30 - Rubber Woofer Surrounds?
machineage
United Kingdom
Posts 69
machineage Posted: Thu, Mar 22 2018 4:52 AM
Hi all
I have a pair of C30 loudspeakers. The woofers appear to have surrounds that are quite different to the usual foam surrounds of other Beovox woofers. They feel and look like rubber and there is no deterioration at all in the material. Does anyone know if these drivers were fitted with rubber surrounds at any stage in their production life?
I've enclosed a photo.
Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 23 2018 7:24 AM
The woofer in the photo looks perfectly original for this Beovox model.
machineage
United Kingdom
Posts 69
Thanks Martin Smile
Do you know what this surround would be made from?
It looks and feels exactly like rubber and nothing like the foam used in other Beovox models.
Ben_S
UK
Posts 631
Ben_S replied on Fri, Mar 23 2018 8:20 AM
I agree with Martin, it looks original to me.  The C75 uses the same woofer.
I think the surrounds are rubber rather than foam.
Ben
Dillen
Posts 13,191
Dillen replied on Fri, Mar 23 2018 8:25 AM
I can't say what the surround material is.
I never had many problems with it and never worried much about it.
machineage
United Kingdom
Posts 69
Thanks Ben & Martin Thumbs Up
lassfi
Posts 13
lassfi replied on Fri, Mar 23 2018 12:51 PM
Hi machinage
If you have problems with the surrounds in your Beovox C30, then try to read this webpage from a danish dealer. I'll think you can use Google for translation.
Kind regards
Lassfi
lassfi
Posts 13
lassfi replied on Fri, Mar 23 2018 12:53 PM
Sorry I missed the link :
https://bekent.dk/selvbyg-hojtalere1/hojttaler-reservedele/kantophaeng-bang-og-olufsen.html
regards
Lassfi
Page 1 of 1 (8 items) | RSS
