App + Avant 55
Beosince98
Posts 274
Beosince98 Posted: Sat, Mar 24 2018 1:42 PM
Is it me or is it not possible to play music from my NAS over the Beovision Avant 55, using the App? If so, why????
Sandyb
Posts 2,186
Sandyb replied on Sat, Mar 24 2018 1:51 PM
The old BeoRemote App allows you to do it, as it can see HomeMedia (i.e. your NAS).
Selecting something to play requires looking at the TV screen of course, but the BeoRemote app does give you some measure of control.
I wouldnt expect NAS libraries to be folded in to the new App - i think that has been made fairly clear by the dev team, unfortunately.
Beosince98
Posts 274
So I can play music from my NAS to an Beoplay A9 MK2 via the App but not to my very expensive TV?
Sandyb
Posts 2,186
Sandyb replied on Sat, Mar 24 2018 2:13 PM
Hmm, you can if your NAS in connected to a Moment (possible a Core / Essence, dont have one so cant say for sure).
I can use the App (latest one) to play my NAS music on my Avant, but my NAS is connected to a Moment.
I have an A9 too - how can you play NAS music through the A9? Selecting my A9 in the app, not obvious to me which source option would relate to a NAS alone.
Beosince98
Posts 274
Sandyb:
I have the NAS setup as a DLNA source. I want to simply play music to my Beovision through the App, not using Homemedia. However, if I choose a song I want to play on the Beovision i get an error saying that this is not possible.
Sandyb
Posts 2,186
Sandyb replied on Sat, Mar 24 2018 4:16 PM
They are not planning on building in DLNA support to the new / current app.
I suspect the answer re the Avant is that it needs a Moment / Core / Essence connected, others may well be able to advise.
Appreciate that's not the answer you need.
ngnear
Posts 245
ngnear replied on Sat, Mar 24 2018 4:17 PM
I have the same issue with an M5 and an Avant 55 (1Gen)
A workaround is to start playing on the M5, join the Avant to the multiroom group and then mute the M5.
This may also be possible with your A9
Tim
Page 1 of 1 (7 items) | RSS
