Where to find Speakerlink 4-pin connectors/cables
This post has 7 Replies | 3 Followers
gogipopovic
Posts 1
gogipopovic Posted: Wed, Mar 28 2018 1:59 PM
Does anyone know where I can buy 4-pin Speakerlink cables or at least the connectors?
"Soundsheavenly" is out of stock as it seems....
I need the cables for my Penta 1's speakers and Beomaster 5500.
Thanks in advance.
Regards,
Goran
Guy
Warwickshire
Posts 2,590
Guy replied on Thu, Mar 29 2018 8:57 AM
I would have said Steve, but maybe try here: http://www.avaservices.co.uk/
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Goran,
I will have the cables back in stock on Tuesday of next week, sorry for the slight delay!  Would you like me to let you know when they arrive?
Kind regards,
Steve.
Steve.
www.soundsheavenly.com
Posts 2,165
Hi Goran,
Thanks for your patience, the plugs and cables are back in stock today.  Please ask if you need any further help.
Kind regards, Steve.
Steve.
aymeric
Leiden
Posts 158
aymeric replied on Thu, Sep 19 2019 7:55 PM
Got them listed on ebay, you will find them!
Every lenght, not original but it works :)
Posts 2,165
Hi aymeric,
The centre pin is the wrong shape and too small on the plug in your photo, this won't work well on older B&O speakers and systems that have worn sockets.  I recommend using cables with the original B&O "spade and 3 pin" plugs to avoid issues.
Steve.
aymeric
Leiden
Posts 158
aymeric replied on Fri, Sep 20 2019 8:09 AM
They can try and return them for a small price :)
Posts 2,165
Hi aymeric,
You need to be aware that buyers can quite rightly ask you to pay for the return postage under European law if these leads don't work on their speakers.  This is because the plugs are not compliant with B&O's specifications, so the buyers can claim that the leads are not suitable for their intended purpose.
Steve.
Page 1 of 1 (8 items) | RSS
