Does anyone know where I can buy 4-pin Speakerlink cables or at least the connectors?
"Soundsheavenly" is out of stock as it seems....
I need the cables for my Penta 1's speakers and Beomaster 5500.
Thanks in advance.
Regards,
Goran
I would have said Steve, but maybe try here: http://www.avaservices.co.uk/
Hi Goran,
I will have the cables back in stock on Tuesday of next week, sorry for the slight delay! Would you like me to let you know when they arrive?
Kind regards,
Steve.
www.soundsheavenly.com
Thanks for your patience, the plugs and cables are back in stock today. Please ask if you need any further help.
Kind regards, Steve.
Got them listed on ebay, you will find them!
Every lenght, not original but it works :)
Hi aymeric,
The centre pin is the wrong shape and too small on the plug in your photo, this won't work well on older B&O speakers and systems that have worn sockets. I recommend using cables with the original B&O "spade and 3 pin" plugs to avoid issues.
They can try and return them for a small price :)
You need to be aware that buyers can quite rightly ask you to pay for the return postage under European law if these leads don't work on their speakers. This is because the plugs are not compliant with B&O's specifications, so the buyers can claim that the leads are not suitable for their intended purpose.
