Hello
I have a Beogram 2300 (which I believe is to be the same as a 1900-2)
I currently only have a set of good quality 8 ohm speakers.
The sound isn't anywhere near as good as I was expecting. I tried the same on an old Beocenter which sounded a lot better.
I have ordered a set of capacitors from Martin. Am I likely to get an improvement in sound quality or do these amplifiers really need to be paired with B&O 4 ohm speakers?
Paul
What do you mean exactly when you say "better", "good" etc.? Is the issue with the volume scale, distortion, certain frequencies? Without knowing this it is probably hard to say anything meaningful.
