Beogram 2300 (1900) Poor Sound Quality
This post has 1 Reply | 0 Followers
paul_f
Posts 12
Silver Member
paul_f Posted: Wed, Mar 28 2018 7:09 PM
Hello
I have a Beogram 2300 (which I believe is to be the same as a 1900-2)
I currently only have a set of good quality 8 ohm speakers.
The sound isn't anywhere near as good as I was expecting. I tried the same on an old Beocenter which sounded a lot better.
I have ordered a set of capacitors from Martin.  Am I likely to get an improvement in sound quality or do these amplifiers really need to be paired with B&O 4 ohm speakers?
Paul
peternovy
Posts 53
peternovy replied on Thu, Mar 29 2018 4:18 PM
What do you mean exactly when you say "better", "good" etc.? Is the issue with the volume scale, distortion, certain frequencies? Without knowing this it is probably hard to say anything meaningful.
Page 1 of 1 (2 items) | RSS
