Beocenter 2300 Laser not working
This post has 11 Replies | 1 Follower
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR Posted: Thu, Mar 29 2018 1:12 PM
Laser dose not work on a Beocenter 2300, all i get in the display is CD < >
Anybody know what this means,
Ken
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 29 2018 3:05 PM
kentaylor:
Ken
It means you need to change the laser :)
Lots of threads about it, and it is not that difficult.
/Jacob
JKW TAYLOR
Nederland
Posts 140
Thanks, is there an upgrade?
Ken
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Mar 29 2018 5:16 PM
An upgrade to the laser?
What would it be, you are hoping to achieve?
JKW TAYLOR
Nederland
Posts 140
Sorry, i mean what is the number for the laser, has there been a upgrade from the original laser. Or is it a specific laser for the 2300
Ken
Weebyx
Denmark
Posts 1,213
Weebyx replied on Thu, Mar 29 2018 7:31 PM
kentaylor:
Ken
The laser is most likely the CDM 12.4 version. If it is the version with curved laser, then it is not the laser that is the problem, but if it is the straight version going from middle to the buttom, then it is the 12.4 version. Beosound 3000 had the laser upgrade to VAU1255, but I have never seen this in the 2300.
But to be sure, you need to look at the unit in your 2300, to be sure. It will probably say CD PRO2 or something, and this is the CDM 12.4 laser that can be used for them. To be sure you can remove the laser, and be sure that the laser you get has the same numbering on the flatcable of the laser.
/Jacob
JKW TAYLOR
Nederland
Posts 140
Thanks for the info
Ken
JKW TAYLOR
Nederland
Posts 140
Thanks for the info
Ken
JKW TAYLOR
Nederland
Posts 140
Just found this video on youtube
https://www.youtube.com/watch?v=DbEW8qvY1Pc
Shows how to replace the CDM12.4
Ken
JKW TAYLOR
Nederland
Posts 140
JKW TAYLOR replied on Sat, Mar 31 2018 12:21 PM
SOLVED, cleaned the lens for 10 seconds with a cotton tip !
Laser works 100%
Ken
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
kentaylor:
Laser works 100%
Ken
That cure won't last forever, sooner or later the laser will fail and will need to be replaced.
Regards Graham
ipaul
Posts 422
ipaul replied on Sun, Apr 1 2018 9:07 AM
With internet: everything is easy, anyone can do it and they always tell the thruth ...:)
if it fails again and you don't have experience in repairs, tools, and parts, find someone who does to do this for you instead of risking to mess up your system.
someone who knows about this, can do the job in 1 hr tops..
Page 1 of 1 (12 items) | RSS
DigiCert Secured Site Seal
