Free parts from Ouverture/2300/2500
This post has 21 Replies | 2 Followers
leosgonewild
Helsinki, Finland
Posts 2,373
leosgonewild Posted: Wed, Apr 4 2018 8:03 PM
I have an ongoing project, and I am using an Ouverture for this.
A lot of parts I do not need. I at least have a working cd mechanism if someone needs it.
Some other parts also, like the plastic parts and other stuff. Tell me what you need.
I tried the cassette player before disassembly, and I only got sound on right channel.
What is not for grabs is:
the power supply, inputs, ir-board and display.
leosgonewild
Helsinki, Finland
Posts 2,373
and the glass doors never existed.
delroy
Posts 43
delroy replied on Wed, Apr 4 2018 10:06 PM
I call dibs on the cd mechanism and accompanying pcb, I am in need of a spare one.
leosgonewild
Helsinki, Finland
Posts 2,373
Send me a pm with address. Is the PCB the first board that the wires attaches to?
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Same here, some experimenting and ejecting the tape mechanism.
Beobuddy
Posts 3,972
Different material used.
Beobuddy
Posts 3,972
Need still some tweaking as the upc expects signals from the tape, which isn't there anymore.
So, another tape deck available ..
leosgonewild
Helsinki, Finland
Posts 2,373
How do you reprogram the display to show CAST?
Do you know if there would be any way to connect a Gramofon to the CD-input and make the remote skip tracks?
Beobuddy
Posts 3,972
leogoeswild:
By scrolling through the software and looking for TAPE and modify that. with CAST then reprogram the chip (if it's a Xicor). For private use btw.
TWG
Posts 1,672
TWG replied on Thu, Apr 5 2018 1:39 PM
Great projects you guys have there! Yes - thumbs up
Would you mind to open a new thread like "Ouverture/2300/2500 modding"? Highly interested!
Beobuddy
Posts 3,972
leogoeswild:
The first challenge will be to let the micro think that there is still an CD player which delivers data about it's status. Without that the Ouverture won't open the audioinputs and shuts off after a while.
I assume that the Gramofon is used with an app, so to control via Beo4-Ouveture-Gramofon will be the next challenge as there isn't a kind of remote that comes with the gramofon that you can  simulate.
Beobuddy
Posts 3,972
TWG:
Still thinking over about how to interact with the processor.
I can rebuild a small part from the Tape PCB to simulate the presence of it, or use a Arduino to make it a bit more sophisticated and let the microprocessor know when the music stopped from the Google dongle, so it shuts off automatically.
With this mod, you still will have the CD and the extra A.AUX input for another source at the back.
When completed we could start a topic with the complete modification.
leosgonewild
Helsinki, Finland
Posts 2,373
What is needed to connect to the software and reprogram the chip? I have no idea how that works, so teaspoon feeding please :P
Your project looks great btw :)
Here is how my project looks so far:
https://www.youtube.com/watch?v=sF6XzAU4K2k
BEOVOX141
Denmark, West
Posts 711
@Leogonewild
Pull the Eprom (27C512 ?) and dump the content with an EPROM programmer (ALI is your friend :-) )
In a Hexeditor find TAPE and replace with CAST, depending on how the software is organized you may even be able to replace with more letters.
...Or whatever else you can think of Smile
The Cast picture shows checksum is not an issue, so simply program a new chip, leaving the old as a backup!
This trick, unfortunately, doesn't work for e.g. your Penta displays since its a mask-programmed device, meaning you cant dump the content of the internal ROM.
Since B&O now wants to be seen as the Upcycling company, perhaps it would be prudent if the mask programmed software for the old classics would be made available, otherwise, the whole Beocreate idea could easily be construed as just - fluff!
leosgonewild
Helsinki, Finland
Posts 2,373
Looks like a lot of stuff to get into for a newbie like me. Could be fun, but I don't think I would ever use that knowledge ever again.
Would it be possible for one of you to make a chip for me?
BEOVOX141
Denmark, West
Posts 711
@Leogoeswild
leogoeswild:
That what I was thinking when i "customized" a DOS 2.11 disk more than 30 years ago Smile
Tell you what,- I would be glad to give it try this weekend, and I will let you know,- we are all Beolovers  Smile
Incidentally, I might have something else you could use,- The Beochrome, more to come!
leosgonewild
Helsinki, Finland
Posts 2,373
If the A.AUX could be changed to CHROMECAST(preferred) or CAST
and PHONO could be changed to SPOTIFY, that would be awesome!
If there is A.TAPE2 in there, maybe it could be changed to BEOCREATE or CREATE Stick out tongue
Very excited to hear about the Beochrome Lets have a Party !!!
Beobuddy
Posts 3,972
Beobuddy replied on Fri, Apr 6 2018 12:28 PM
No more than 8 characters.
leosgonewild
Helsinki, Finland
Posts 2,373
SPOTIFY
RECREATE
BEOCAST
Big Smile
Beobuddy
Posts 3,972
leogoeswild:
SPOTIFY
RECREATE
BEOCAST
Big Smile
@ which positions?
BEOVOX141
Denmark, West
Posts 711
@Beobuddy (cc: Leogoeswild)
Are we going to have an issue with SW version if I make a chip for Leogoeswild... ?
Wouldnt it be even cooler if we could propagate the change to the PENTA display,- any ideas?
leosgonewild
Helsinki, Finland
Posts 2,373
a.aux -spotify
phono- recreate
a.tape2 - beocast
Would it be possible to build new displays for the Penta`s?
The ICEpower amps I have built into them has unregulated output.
Page 1 of 1 (22 items) | RSS
