Beolab 4500 + Beovox 4500, connection question
Siegfried
Haren NL
Posts 6
Siegfried Posted: Tue, Apr 10 2018 12:56 PM
Hello everyone,
On the wall:
BeoSystem 4500 + Beolab 4500
To install:
Beovox 4500, not sure if it will be in the same room or to extend the sound into the kitchen
My thought/fantasy would be to connect them to the BV4500 AFTER the amplifier. Is this possible or will this ask to much from the amps?
Or do i connect an pre-amp to the BS4500 and then connect the BV4500 to that?
Or just plain connection to the two pin socket on the BS4500?
Grtz
My first B&O!!
Beocenter 9000
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi Siegfried,
Beomaster 4500 is a superb system as it has both amplified and pre-amp outputs, which can both be used at once.  Hence, you can connect a pair of powered Beolab 4500 speakers to the Powerlink sockets of the Beomaster with fully wired Powerlink mk.2 cables (https://soundsheavenly.com/powerlink-8-pin-din-connection/powerlink-mk-2-compatible-black-8-pin-din-cable-with-fully-wired-8-cores) as well as connecting the Beovox 4500 speakers to the 2 pin "Speaker 1" sockets of the Beomaster with regular passive speaker wires and DIN plugs: https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/
This won't cause any problems, or overload the amplifier of the Beomaster, in fact you can connect up to 2 pairs of passive Beovox speakers and several pairs of powered Beolab speakers at once without any issues.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
