B&O system with non B&O TV
This post has 20 Replies | 0 Followers
johnheartfield
Posts 20
johnheartfield Posted: Sat, Apr 14 2018 11:21 AM
I know there are other threads on a similar topic but as time goes by so do solutions...
I have a BeoVision 7-40 HD (the early one with no HDMI) with an attached BL 7.4. This is the centre of a system with a BeoSound 9000 and 2 X BL 8000's at front and 2 X BL 6000's at rear. There is also a BeoLab 2. Everything is "plumbed in" using ML. The speakers are the older ones.
I want to change my TV to a non B&O option. Question is how can I keep the rest of my system in place and still make everything work as is with minimal relocation of wires etc? The 9000 is on the wall with wires plastered in!!
Inferno82
Posts 47
Inferno82 replied on Sat, Apr 14 2018 11:29 AM
I think only with beosystem 3?
johnheartfield
Posts 20
Had not thought of thatSmile. Thank you. I know you can still buy them. Anyone with experience of using this with something like an LG OLED?
OldJack
Split
Posts 371
OldJack replied on Sat, Apr 14 2018 1:12 PM
Or Almando ? There are posts about Loewe oled/Almando integration.
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
johnheartfield
Posts 20
Thanks for the suggestion. Always worry a little when things are run by an app given Apple’s lack of continuing support and updating issues for them some times.
Raeven
Posts 61
Raeven replied on Sun, Apr 15 2018 4:47 PM
As I have reported in an other post I have installed the Almando in a similar setup. In order to connect the ML you need to add a B&O link active. Works perfectly for me. The app of Almando is (actually two app's either Apple or Android) is only used to setup the speakers (volume etc). Once this is done you never use the app again.
Good luck!
kai
Posts 362
kai replied on Sun, Apr 15 2018 6:23 PM
Hi Raeven
I hope you don’t mind me asking I have asked a question on something similar, beovision 4-50 non hd, I’m going to replace this with a non bango tv, however I still have the beocentre 2, do I simply use a beolink active to connect the beocentre 2, and still use the radio and cd command, how is the volume controlled
Mikipidia
Posts 2,169
Mikipidia replied on Sun, Apr 15 2018 11:05 PM
@raeven
What is the app called in the apple app store? I can’t seem to find it, thanks in advanceYes - thumbs up
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Raeven
Posts 61
Raeven replied on Mon, Apr 16 2018 3:17 PM
Hello the app is called: Almando Control. But I think the app is still in test by Apple. If you buy an Almando product just mail them and you will receive an invitation to Testflight then you download and run the app. The android app is normally available in the google store. I work with the Apple app works perfectly. If you want I can post some screen shots.
Mikipidia
Posts 2,169
Mikipidia replied on Mon, Apr 16 2018 11:51 PM
Hi Reaven,
yes please, I'd be very interested in that. I still have an eclipse, the key word being ''still''. iam not that happy so iam looking at all options they way I feel I should've done when I bought my new setup.. anywho I'd love to see how it works and what you could do with speaker control etc. thanks!
Aussie Michael
Melbourne, AU
Posts 3,730
I’m going the axiim q route for my Sony OLED A1
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Tue, Apr 17 2018 4:12 AM
Hi Reaven,
How would you rate the Almando DAC? Did you notice any quality drop in sound due to use of a non-BO TV?
Sweden
Posts 357
Silver Member
Martin replied on Tue, Apr 17 2018 6:54 AM
Hi Mikipedia,
why are you not happy with your Eclipse?
I am satisfied with mine besides that I experience sometimes NO sound when starting Deezer or MUSIC from NAS. But I got message from my dealer that this software bug is beeing corrected very soon.
I really like the PQ of the Eclipse and that the Tv support all major PQ format (dolby vision and HDR).
Best regards
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Sweden
Posts 357
Silver Member
Hi Mikipedia,
Best regards
Epsilon20
Posts 58
Epsilon20 replied on Tue, Apr 17 2018 10:08 AM
Axiim is WISA compliant so have scope to add B&O speakers later.
Beovision Eclipse 55 Brass Edition with Oak covers and Brass Orbital stand
Beolab 50s silver & Oak, Beolab 18 Brass with Smoked Oak, Beolab 18 Rose Gold with Maple Covers, Beolab 19 Black.
Raeven
Posts 61
Raeven replied on Tue, Apr 17 2018 3:34 PM
Hello I would rate the quality the same as B&O. It took me some time to adjust the volume of the loudspeakers to have the good surround sound.
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Apr 17 2018 7:48 PM
@martin
There is just still too many thing wrong with it. At this point it’s still mostly a moving lg c7. We’re 7 months in and mybuttons aren’t there still and the more i use it the more i find the adverts for it to be on the edge of false. Besides that I may have other issues most people don’t have, it whistles for instance when you turn it off and it may be that it’s not work properly in conjunction with my bl50’s that are also very iffy again. It’s not fun being a B&O customer anymore.
@reaven
Have you managed to make some screenshots of the app and what kind of adjustability you have in there? Thank you in advanceYes - thumbs up
Raeven
Posts 61
Raeven replied on Wed, Apr 18 2018 7:19 AM
Hello Mikipedia,
I have made small screen-recording on my iPhone which explains  a bit the functionality. See attached download link, if the link does not work PM and I will send you another link.
1 I go to settings on the phone to connect the Almando
2 Open de Almando app
3 Here I put on the TV and you see "HDMI ARC" turns red. As you can see the input signal is PCM, this can be changed in the TV settings and the Almando will follow
4 here I demonstrate/show the different settings of the loudspeakers
5 Turn the TV off
6 Turn the BeoLink on the "DIN (B&) Powerlink) turns blue
7 show setting of the powerlink, under de menu "DOWNMIX" you can select which speaker set you want to use.
8 turn off Beolink
9 you can also connect your IPhone via Bluetooth did not demonstrate this, but works perfectly
Here is the link:
https://www.dropbox.com/s/1gkkclm553ztt4u/ScreenRecording_04-17-2018%2011-21-08.mp4?dl=0
stampfki
Posts 138
stampfki replied on Wed, Apr 18 2018 10:21 AM
Putzgrilous:
Hi Reaven,
Well, I haven't made a side by side comparison, but TV sound from LOEWE is pleasant. When playing from Essence the Almando DAC is not involved.
Only thing I noticed when streaming Music via Bluetooth the Almando Multiplay, it sounds crappy. I can also Bluetooth to the LOEWE built-in module which is perfect then.
Mikipidia
Posts 2,169
Mikipidia replied on Wed, Apr 18 2018 12:20 PM
Thanks Raeven, that looks like a very decent interface. Very easy to use and configure
elephant
AU
Posts 8,219
elephant replied on Wed, Apr 18 2018 12:45 PM
Aussie Michael:
Not to rain on your parade but did you see this poorly written “review”/ story ?
Unforgivable flaw with $6000 TV - news.com.au
https://apple.news/Ae0BthWy8RBabsS5Rb3dgoA
BeoNut since '75
Page 1 of 1 (21 items) | RSS
