NAS/MOMENT
Druers
Posts 1
Druers Posted: Mon, Apr 16 2018 12:13 PM
Hi there I am interested in buying a NAS device on which to transfer my CDs to play via my Moment. Any suggestions please on which NAS would be suitable and not cost the earth. Thanks. Bill.
Hiort
Sweden
Posts 2,895
Hiort replied on Mon, Apr 16 2018 3:31 PM
Druers:
I use a Synology NAS and using the built in DLNA server. The majority of the cost are the disk size you want to use.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Mon, Apr 16 2018 4:17 PM
I use a PC dedicated as server ("to fast" processor, "excessive" memory, but cheaper).
DLNA server: Minimserver
Kiran
UK
Posts 1,023
Kiran replied on Mon, Apr 16 2018 4:31 PM
2 bay NAS from Seagate works perfectly well for me. Around £350 with disks.
Regards
Kiran
Born in NL; I ride ML
Sandyb
Posts 2,186
Sandyb replied on Mon, Apr 16 2018 5:01 PM
I use a QNAP 251, with their own music server feeding the Moment.
Been pretty impressed actually - no issues, and their web GUI is very decent.
Around 270 GBP on Amazon.
laseralex
Posts 240
laseralex replied on Tue, Apr 17 2018 6:33 AM
I'm using a Raspberry Pi set up with Twonky Server, which was pretty easy to do using these instructions from Weebyx.   If you have never dealt with Linux and aren't comfortable with command-line work on a computer, it may be a bit much.
Cost was $70 USD for a Raspberry Pi starter kit (R-Pi, SD card, case, power supply) plus $5 for a USB HDD carrier to hold an SSD I already owned as a spare.  If you got your Moment new from a dealer you should already have a Twonky license; I got my Moment used so needed to buy the Twonky license for another $20.
I haven't actually measured the power consumption, but one reason I went for the Raspberry Pi and SSD was the minimal power draw when idle.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II
Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2
Integrated:  1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6
Control:  16x* Essence Remote  • 1x Beoremote Halo
* Yes, really! 🤦‍♂️
Page 1 of 1 (6 items) | RSS
