Hi there I am interested in buying a NAS device on which to transfer my CDs to play via my Moment. Any suggestions please on which NAS would be suitable and not cost the earth. Thanks. Bill.
Druers:Hi there I am interested in buying a NAS device on which to transfer my CDs to play via my Moment. Any suggestions please on which NAS would be suitable and not cost the earth. Thanks. Bill.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
I use a PC dedicated as server ("to fast" processor, "excessive" memory, but cheaper).
DLNA server: Minimserver
Regards
Kiran
Born in NL; I ride ML
I use a QNAP 251, with their own music server feeding the Moment.
Been pretty impressed actually - no issues, and their web GUI is very decent.
Around 270 GBP on Amazon.
I'm using a Raspberry Pi set up with Twonky Server, which was pretty easy to do using these instructions from Weebyx. If you have never dealt with Linux and aren't comfortable with command-line work on a computer, it may be a bit much.
Cost was $70 USD for a Raspberry Pi starter kit (R-Pi, SD card, case, power supply) plus $5 for a USB HDD carrier to hold an SSD I already owned as a spare. If you got your Moment new from a dealer you should already have a Twonky license; I got my Moment used so needed to buy the Twonky license for another $20.
I haven't actually measured the power consumption, but one reason I went for the Raspberry Pi and SSD was the minimal power draw when idle.
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
