Just called a dealer to ask about the BV11 and he mentioned the BV7-40 will be discontinued, while the BV7-55 will remain. Too bad as I really find the BV7-40 perfect, except was waiting to see it would be updated with the smart functionality.
I have yet to see the BV11 live, but any comments as to how the PQ compares with the 7-40? Sound wise I was looking to connect to BL-1s so y assumption that a BV11 would be the same as a BV7-40 under this configuration for sound?
BV11-55, BS9000, BL1, BL19, Transmitter 1, Beo4, Beocom 6000, BeoTalk1 200, Sennheiser HD600, McIntosh MHA100
That the BV 7 (not yet the -55) soon will be discontinued is nothing new.
"A replacement" based on the new videoengine is expected for spring 2013.
No details out yet - but will probably be an evolution on the outside (maybe a bit more than just an evolution), and a revolution on the inside - as ceo Tue Mantoni described the BV11.
Greetings Millemissen
Thanks for the feedback...I saw the bv10 earlier this year and was not impressed with the sound nor the picture quality compared to the 7-40...I was hoping for some tremendous improvement with the BV11. So I guess this becomes a question of waiting to see any innovation on the bv7, and determining whether the BV11 is good enough (at almost half the price)...
