Discovering how an NL/ML Converter IR eye will NOT work with a BeoVision 10
This post has 10 Replies | 1 Follower
beojeff
USA
Posts 2,012
beojeff Posted: Mon, Apr 23 2018 10:55 PM
I'm wondering if there are others who are frustrated with B&O's poor design of the BeoVision 10 with regard to its IR receiver. Unlike most BeoVisions that have the IR receiver at the TOP of the screen, the BeoVision 10 has the IR receiver at the bottom of the screen. This makes controlling a BV 10 from bed in a bedroom rather awkward. To get a clear aim with the B&O remote, you must somewhat lift the remote high in the air and point it downward. Sadly, B&O didn't even provide the option to connect an external eye as some BeoVisions do.
By BeoVision 10 is located in my bedroom with a Moment using its speakers via an NL/ML Converter. Since I have another BeoVision (located in the living room) as my Video Master connected to the BLGW, I need to the an IR eye connected to the NL/ML Converter anyway in order to transmit LIGHT/CONTROL commands to the BLGW.
I thought I would try a test to see if having the NL/ML Converter IR eye in Link Option 2 would allow me to use THAT IR eye to also control my BeoVision. Sounds like a good idea. Right? The NL/ML Converter manual does not mention this as a use, but I thought I would try it anyway. No luck. It seems that the NL/ML Converter IR eye is really just there to control for speakers connected to the NL/ML Converter -- as indicated in the manual. Such a shame. This would have been a nice feature. I had to set my NL/ML Converter IR option back to Option 4.
I just thought I would share my failed test.
elephant
AU
Posts 8,219
elephant replied on Tue, Apr 24 2018 12:12 PM
Usually the Beo4’s transmission is strong enough we don’t need to point it in the direction of the BV ! Let alone try to aim it at the sensor !!
Have you got either the transmitter or/and the receiver configured for low intensity like the do in the stores to prevent demonstrations interfering with one another ?
May not be a BV10 option but perhaps worth checking ?
BeoNut since '75
beojeff
USA
Posts 2,012
beojeff replied on Tue, Apr 24 2018 9:27 PM
Do you know how to check the IR strength setting on the BV10? I couldn't find anything - even in the service menu. I had always thought the IR strength was just in the remote control setting. I have the same issue with the BeoVision 10 with all of my remotes. The edge of the bed is definitely an obstruction to the IR signal.
Mikipidia
Posts 2,169
Mikipidia replied on Tue, Apr 24 2018 10:35 PM
Thats weird, my bv10 beo 4 combo used to work even from underneath a light blanket. At my old house it had no issue to go around corners either where there no line of sight at all. I always though back then it was an rf remote until i looked in to itStick out tongue maybe it’s time to change the batteries? Give that a try first. Hope that solves your issue?
Also, a dealer told me of a similar issue once, check if you can if your sockets are propperly wired and you don’t have a ground leak. Apparently that can cause some issues.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
elephant
AU
Posts 8,219
elephant replied on Tue, Apr 24 2018 10:39 PM
Thanks Miki — two good pointers for Jeff
BeoNut since '75
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Apr 24 2018 11:06 PM
beojeff:
Try a factory reset.
Even if that means setting it all up again....
Ralf
beojeff
USA
Posts 2,012
beojeff replied on Wed, Apr 25 2018 2:47 AM
kallasr:
beojeff:
Ralf
That's not happening. That was not a very constructive suggestion.
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Apr 25 2018 6:05 AM
I had an issue before: max. volume was 60, so too low in some cases. Factory reset helped to solve it.
Ralf
PS: I was trying to help, but will stop here. Your comment was not very friendly....not used to it in this forum. Times are changing, I guess.
beojeff
USA
Posts 2,012
beojeff replied on Wed, Apr 25 2018 8:37 PM
kallasr:
Ralf
I do appreciate your offer to help and perhaps my response was rather curt. It's just that suggesting a complete factory reset is reckless and should be used just as a last resort. In your situation, you actually did not need to do a factory reset. In the service menu, you could have easily adjusted the maximum volume. There is no such setting in the service menu with regard to the IR reception strength. Unless someone can prove to me otherwise, the adjustment for IR strength is only done in the transmitting remote. My various remotes all have full battery charges and there truly is a substantial obstacle between the remote and were the BeoVision's remote sensor is located: a substantial bed frame and the entire length of the thick mattress.
The purpose of my post was to point out the design flaw of the BeoVision 10 as compared to other BeoVisions and to explore the possibility of using the NL/ML Converter set as A.Master to control the V.Master when the NL/ML Converter is set to Option 2. It's true that the manual clearly indicates that the IR sensor for the NL/ML Converter is intended for use when the Converter has its own speakers connected to it. I was just hoping that the Link settings would be consistent with how the Link settings work with ML products. The purpose for the thread was just to point this out to other B&O users who might be curious.
elephant
AU
Posts 8,219
elephant replied on Thu, Apr 26 2018 7:27 PM
Just some work around suggestions - I hope I am not frustrating you ! It’s my problem solver trait :)
I accept your design criticism especially as “smaller” TVs are likely to end up in bedrooms ! I always liked the V1’s ceiling suspension for the reason the bedrooms can be more cluttered than most rooms.
And I agree it is frustrating when what seems logical (the nl/ml) falters ... if you had other spare multi-room devices with IR eyes they might help picking up and relaying the commands.
However have you tried reflecting the ir signal off a strategically placed mirror ?
BeoNut since '75
beojeff
USA
Posts 2,012
beojeff replied on Thu, Apr 26 2018 8:10 PM
elephant:
Like a mirror on the ceiling? That sounds like QUITE the bachelor pad!
Page 1 of 1 (11 items) | RSS
