Hi there,
I am restoring an really pretty BeoGram 1203. I cleaned the motor and the bearings and the speed is perfect again.
But there's a problem i haven't solved yet - the arm is not always engaging when i press the "LIFT"-button.
Sometimes i have to unplug the power and wait a minute or two before it works as expected.
Can anyone tell me what to do to make the arm engage every time? Which part do i need to change?
Thank you,
Christian
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
check and clean all contacts and switches
Søren Mexico: check and clean all contacts and switches
I have cleaned almost everything but i will try it one more time.
Is there any capacitors i should check? Can the relay be faulty or something like that?
After cleaning all contacts one more time and lubricating all mechanical parts, the issue persists.
It is almost consistent: i clean the machine, assemble it, press "LIFT" and the arm engages plays the record and returns.
When pressing "LIFT" again the plate starts spinning but the arm does nothing.
I will add some pictures later today.
Had the same problem with a BG 3000, check here
Søren Mexico: Had the same problem with a BG 3000, check here
Thank you. I guess that you are referring to the following from the other thread:
Søren Mexico: Opened the relay, the contact pins were bend and not making contact, straitening helped, the lower of the two arms did not make sufficient contact to the plastic arm on the cam gear I adjusted the relay position with the factory sealed adjusting eccentric, I checked he cap, diode and resistors all measured OK.
Are the marked pins the ones you referrer to as contact pins? If so, how did you manage to straiten them without destroying them? I will check the resistors, capacitors and diode. And one last question: what to you mean by "factory sealed adjusting eccentric"?
Thank you for your time and help. It is appreciated.
The contact pins/blades are easily bend without problems, but check first if needed, The adjusting eccentric is below the relay if I remember right, sealed with white lacquer (this on a BG 3000) dont know if your model has it
Søren Mexico: The contact pins/blades are easily bend without problems, but check first if needed, The adjusting eccentric is below the relay if I remember right, sealed with white lacquer (this on a BG 3000) dont know if your model has it
Thank you - that did the trick.
