BeoGram 1203 arm not always engaging
This post has 7 Replies | 0 Followers
Christian Leicht
Aarhus, Denmark
Posts 72
Christian Leicht Posted: Mon, May 7 2018 6:20 PM
Hi there,
I am restoring an really pretty BeoGram 1203. I cleaned the motor and the bearings and the speed is perfect again.
But there's a problem i haven't solved yet - the arm is not always engaging when i press the "LIFT"-button.
Sometimes i have to unplug the power and wait a minute or two before it works as expected.
Can anyone tell me what to do to make the arm engage every time? Which part do i need to change?
Thank you,
Christian
Kind Regards,
Christian Leicht
https://leicht.io - B&O Custom Parts & 3D Models
Søren Mexico
Mexico City
Posts 6,411
check and clean all contacts and switches
Christian Leicht
Aarhus, Denmark
Posts 72
Søren Mexico:
I have cleaned almost everything but i will try it one more time.
Is there any capacitors i should check? Can the relay be faulty or something like that?
Kind Regards,
Christian Leicht
Christian Leicht
Aarhus, Denmark
Posts 72
After cleaning all contacts one more time and lubricating all mechanical parts, the issue persists.
It is almost consistent: i clean the machine, assemble it, press "LIFT" and the arm engages plays the record and returns.
When pressing "LIFT" again the plate starts spinning but the arm does nothing.
I will add some pictures later today.
Kind Regards,
Christian Leicht
Søren Mexico
Mexico City
Posts 6,411
Had the same problem with a BG 3000, check here
Christian Leicht
Aarhus, Denmark
Posts 72
Søren Mexico:
Thank you. I guess that you are referring to the following from the other thread:
Søren Mexico:
Opened the relay, the contact pins were bend and not making contact, straitening helped, the lower of the two arms did not make sufficient contact to the plastic arm on the cam gear I adjusted the relay position with the factory sealed adjusting eccentric, I checked he cap, diode and resistors all measured OK.
Are the marked pins the ones you referrer to as contact pins? If so, how did you manage to straiten them without destroying them? I will check the resistors, capacitors and diode. And one last question: what to you mean by "factory sealed adjusting eccentric"?
Thank you for your time and help. It is appreciated.
Kind Regards,
Christian Leicht
Søren Mexico
Mexico City
Posts 6,411
The contact pins/blades are easily bend without problems, but check first if needed, The adjusting eccentric is below the relay if I remember right, sealed with white lacquer (this on a BG 3000) dont know if your model has it
Christian Leicht
Aarhus, Denmark
Posts 72
Søren Mexico:
Thank you - that did the trick.
Kind Regards,
Christian Leicht
Page 1 of 1 (8 items) | RSS
