One of the features I really like with Deezer is their "flow" concept. Is there some way (aside from bluetooth) to play "flow" from my Eclipse or Essence? That is, for whatever reason, I cannot get the Deezer app to "Chromecast" (I get no "Chromecast" icon, and have dug through various support forums about how to fix, but no success). Meanwhile, Essence and Eclipse have Deezer "built-in", but the Beo app doesn't seem to support "flow" (that I can see).
Anyone have Deezer flow working with their B&O device?
Thanks,
Stan
Hi Stan
It seems the flows are only available from the Deezer app...
I just tried and was able to cast one flow from the Deezer app to my M3.
Are you sure your Eclipse and your Essence have GoogleCast enabled?
If not, you may add a cheap ChromeCast Audio dongle...
jans: The B&O app indicates that is is playing from Google Cast. However, it is NOT playing.
That's another software bug I guess. Getting something similar for months now ... you may have a look for "Critical Events" in B&O app to figure that out.
Here's what I am getting with my BS2 (Chromecast shows connection, but does NOT play, NO sound.
I even didn't get an answer from Beocare whether or not this issue will be fixed.
After powering off and reconnecting it works.
jans:The Essence stopped playing iTunes. The B&O app indicates that is is playing from Google Cast. However, it is NOT playing.
Stan:One of the features I really like with Deezer is their "flow" concept. Is there some way (aside from bluetooth) to play "flow" from my Eclipse or Essence? That is, for whatever reason, I cannot get the Deezer app to "Chromecast" (I get no "Chromecast" icon, and have dug through various support forums about how to fix, but no success). Meanwhile, Essence and Eclipse have Deezer "built-in", but the Beo app doesn't seem to support "flow" (that I can see). Anyone have Deezer flow working with their B&O device? Thanks, Stan
BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
