beomaster
sunday
Posts 11
sunday Posted: Sun, May 20 2018 12:25 AM
Hello recently purchased 4004 beogram,looking for advice on period appropriate beomaster that will also power beovox m75 speakers.thank you in advance
Saint Beogrowler
Saint Paul
Posts 780
The most appropriate would be a '70s BM6000 quad or the BM4400.
Also worth considering would be a BM4000, BM3000, or even a BM1900/BM2400, IMO.
Whichever you choose, look for one that has had maintenance completed or restored or at least has been frequently used.
sunday
Posts 11
sunday replied on Mon, May 21 2018 3:01 PM
Hi Peter thank you for the advice.4400 looks to be the match to 4004.but l did like the design of 2400-2 both units being controlled with remote but unsure if powerful enough to operate m75 beovox which l just now purchased from the Nertherlands regards Kevin
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, May 21 2018 3:50 PM
Beomaster 4400 is operated using mechanical sliderule type controls and pushbutton switches = no remote possible.
(Other than a broomstick long enough to reach from the stereo to the couch, alternatively through the wife command system).
Peter
Earsdon
Posts 11,991
Peter replied on Mon, May 21 2018 10:03 PM
Used both 4400 and 2400-2 and a BG4004 with M100s (very similar) The 4400 is one of the best sounding amplifiers B&O made though rather old fashioned, even at its time of manufacture. The 2400-2 however is perfectly capable of driving them and although it seems less good at controlling the bass, this is only noticeable at high volumes. The 2400 is very beautiful...
Peter
sunday
Posts 11
sunday replied on Tue, May 22 2018 11:00 AM
Hello Peter thank you for responding l do prefer the 2400-2 design & remote functionality was unsure of wattage capability to run m75.regards Kevin
sunday
Posts 11
sunday replied on Tue, May 22 2018 11:06 AM
Hello Martin thank you for responding once again.are you agreeable with Peter the 2004-2 can power  m75 or should l opt for the broomstick-wife option regards Kevin
Dillen
Posts 13,191
Dillen replied on Tue, May 22 2018 11:17 AM
Beomaster 2400-2 would be a fine choice.
It's not as powerful as Beomaster 4400, but it can do what it can do.
If you like/need power, go for the 4400.
sunday
Posts 11
sunday replied on Tue, May 22 2018 1:56 PM
Thank you Martin
Page 1 of 1 (9 items) | RSS
