Hello recently purchased 4004 beogram,looking for advice on period appropriate beomaster that will also power beovox m75 speakers.thank you in advance
Hi Peter thank you for the advice.4400 looks to be the match to 4004.but l did like the design of 2400-2 both units being controlled with remote but unsure if powerful enough to operate m75 beovox which l just now purchased from the Nertherlands regards Kevin
Beomaster 4400 is operated using mechanical sliderule type controls and pushbutton switches = no remote possible.(Other than a broomstick long enough to reach from the stereo to the couch, alternatively through the wife command system).
Used both 4400 and 2400-2 and a BG4004 with M100s (very similar) The 4400 is one of the best sounding amplifiers B&O made though rather old fashioned, even at its time of manufacture. The 2400-2 however is perfectly capable of driving them and although it seems less good at controlling the bass, this is only noticeable at high volumes. The 2400 is very beautiful...
Peter
Hello Peter thank you for responding l do prefer the 2400-2 design & remote functionality was unsure of wattage capability to run m75.regards Kevin
Hello Martin thank you for responding once again.are you agreeable with Peter the 2004-2 can power m75 or should l opt for the broomstick-wife option regards Kevin
Beomaster 2400-2 would be a fine choice.It's not as powerful as Beomaster 4400, but it can do what it can do.If you like/need power, go for the 4400.
Thank you Martin
