How do i connect iMac to Avant
paddy2042
Newtown NSW Australia
Posts 210
paddy2042 Posted: Sat, Oct 20 2012 5:52 AM
I have old 28" VCR Avant and want to use its inbuilt speakers together with connected BL4000's  to play my iMac through. I have tried connecting from Headphones output but cannot work out how to do the rest I cannot get any sound. I would like to connect through the second scary to 6RCA plugs. Do I need to add extras to the menu on Beo4.
I am so confused and would love some advice.
Thank You
HVD
Denmark
Posts 37
HVD replied on Fri, Dec 14 2012 10:38 PM
I surgest that you either use the yellow phono connection for audio on the to right back of the AVANT. Depending on BEO4 model you have, you need to select / program CAMCORD or CAMERA under the List function and activate that.
You can also go througt a SCART connection with PHONO in put and then program the SCART to the right setting or select the rigt on the remote.
Hope it helps.
rudyfonseca
Posts 6
Silver Member
i have conected my iphone and my mac air to my beovision 5 but I'm use airplay you need a airport express ,and airport extreme use the digital out of you stb socket rear the avant and connecting to the airport express in you beo 4 click two times tv for stb use and enjoy
Millemissen
Flensborg, Denmark
Posts 14,680
"...click two times tv for stb use..."
Never heard of that - can you explain what that means?
Greetings Millemissen
rudyfonseca
Posts 6
Silver Member
check you beo 4 push tv  until you avant are in stb   but you can use any digital in
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
