As promised RL140, RL2000 and RL35 reclothing
This post has 27 Replies | 4 Followers
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie Posted: Sat, Oct 20 2012 8:46 PM
This link on my Picasa webalbum shows you the way how I did reclothing my Beovox RL140's.
Lots of pictures...and there must be a slide option when you're in PicasaSmile
Just to give you an idea how big these monsters are...
Brengen & Ophalen
BeoLignage
Sweden
Posts 207
looks nice Leslie!! good work!
My first thought was: how is the "bang & olufsen" text on the fret made... now I know, and how it is reclothed too Smile
which size of a RL speaker is equal or better sound wise compared to a CX100?
Leslie
Posts 5,423
Silver Member
Leslie replied on Sat, Oct 20 2012 9:51 PM
I guess all of them? I don't know to be honest, but I will compare them with my CX100's cause I have them all. Will let you know..
Brengen & Ophalen
DMacri
United States
Posts 881
DMacri replied on Sat, Oct 20 2012 11:37 PM
Great job on them, Leslie. I think I'll have a go at my RL140s now. What kind or double stick tape are you using?
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
DMacri
United States
Posts 881
Dom
Søren Mexico
Mexico City
Posts 6,411
DMacri:
Get the right one, I used a double tape, it was promised to stick on everything for years and came off after one week.
sonavor
Texas, United States
Posts 3,732
sonavor replied on Sun, Oct 21 2012 5:29 AM
Beautiful work as usual Leslie.  I appreciate the detailed pictures.  I too have a few questions though.
1. What brand of double-sided tape?
2. It appears that you brushed some sort of glue on and around the Bang & Olufsen logo first (makes sense - I sprayed on some 3M sticky glue on my first RL140 job).  What kind of glue do you use for that?
3. In your finish steps, what is it that you are brushing on to the plastic frame?
Thanks,
sonavor
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Oct 21 2012 7:51 AM
sonavor:
Thanks,
sonavor
Thanks Sonavor!
1) Tesafix Tesa 4965, use Ebay.de to get them cheap. Don't buy them at Conrad, far to expensive!
2) Bison spray Please note that you have to wait for a minute or two before applying the cloth, or else the glue will appear throught the cloth!!
3) HG sort of spray (wax) used for shining furniture. I use that for almost all materials like aluminium, plastic, wood...
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Sun, Oct 21 2012 8:39 PM
DMacri:
Thanks "DMacri", I guess you alreay read the answer on Sonavors reply? Good luck doing yours Yes - thumbs up
Don't use to thick fabric for the cloth....
Brengen & Ophalen
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Mon, Oct 22 2012 7:55 AM
Leslie, Nice job and great photo sequence .
Orava
Finland
Posts 991
Orava replied on Mon, Oct 22 2012 10:44 AM
Nice job, I did onetime White/White 60s with 3M sprayglu, but it had difficulties to stay on. Got to check this Bison
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Oct 22 2012 11:40 AM
Orava:
That's why the fabrick must be as thin as possible!
Brengen & Ophalen
DMacri
United States
Posts 881
DMacri replied on Mon, Oct 22 2012 11:45 AM
Leslie:
Yes, that answered my question. Now for a new one - where do you get your fabric? I want to make sure I get the right thickness.
Dom
Leslie
Posts 5,423
Silver Member
Leslie replied on Mon, Oct 22 2012 11:54 AM
This is where I get my cloth on Ebay.com. Can be thinner though!
Brengen & Ophalen
Orava
Finland
Posts 991
Orava replied on Mon, Oct 22 2012 12:06 PM
Leslie:
Orava:
Yes, it was. More exercises then...
Paul
Posts 116
Paul replied on Wed, Oct 24 2012 6:23 PM
very good job as always!  Those RL's deserve a new life.  Clever to use double sided tape!  Emboss the B&O text is hard to do isn't ?
I like those DIY pictures it will help. I wish we could place these DIY tuts in a separate Item on this forum.
Mikael
Sweden
Posts 58
Mikael replied on Tue, Nov 6 2012 5:48 PM
Hi!
Truly inspiring pics!
In the picasa album you are using a green tape which I assume is s foam tape? Is it the same used for BC glass panels? Where do you buy it?
Best regards,
Mikael
Beocenter Overture | Beolink passive | CX100 | CX50
Søren Mexico
Mexico City
Posts 6,411
Paul:
They can be placed in the Wiki's but someone has to do itWhistle
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 6 2012 6:11 PM
Mikael:
Hi!
Best regards,
Mikael
Yes it is but I'm not using this tape for glasspanels, much to thick...
Brengen & Ophalen
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 6 2012 6:12 PM
Søren Mexico:
Paul:
Why are you Whistle Soren?
Brengen & Ophalen
Michel
Alkmaar
Posts 26
Michel replied on Tue, Nov 6 2012 6:39 PM
Thanks for uploading these pics Leslie!
I have the middle sized ones in black though. I want to recloth them in light grey or white.
You did a great job and like you, I was already aware of the bison sprayglue which is perfect to use for these kind of projects. I did them once, but wasn't satisfied with the fabric, this looks much better.
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 6 2012 7:40 PM
michgal:
Thank you Michel. Are you sure you want to do it in white or grey? It's quite contagious for stains you know, but great looking!
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
Take a wild guess Leslie
Leslie
Posts 5,423
Silver Member
Leslie replied on Tue, Nov 6 2012 8:47 PM
What's you're link with Beoworld other then posting threads? Serious, did I missed something here?
Brengen & Ophalen
Søren Mexico
Mexico City
Posts 6,411
Leslie:
As we make these thread one time after the other, and answer the same questions the one time after the other, why not make a Wiki like this one and then just post the link when people are asking. The threads tends to disappear in the mass.
Orava
Finland
Posts 991
Orava replied on Mon, Apr 22 2013 1:07 PM
Hi
Leslie:
Is this anywhere near to CX fret? I need for white CX´s.
CR
France
Posts 4
CR replied on Sat, Oct 10 2015 4:10 PM
Hello Leslie! I know this is a pretty old thread but the Picasa album is not working anymore and I was wondering if you still had the photos somewhere :)
Thanks!
Fredthefrogman
Posts 3
Does anyone have any copies of the detailed guide as the link doesn't seem to work for me?
Many thanks,
Dave
Page 1 of 1 (28 items) | RSS
DigiCert Secured Site Seal
